Last updated by Rajeeb Banstola 1 year ago.
Assigned support staff: Rajeeb Banstola.
May 31, 2019 at 9:07 pm
matijaG-2
footer menu on croatian is vertical but footer menu on english is horizontal? - screen 1 in attach
Thnx a lot
May 31, 2019 at 10:56 pm #3933565
Rajeeb Banstola
Thank you for your patience!
The reason the footer menu is vertical in English is because of CSS coding that doesn't target proper id in English language.
You can check your HTML and see that the Crotian footer menu has
menu-horizontal-footer
CSS ID whereas the English menu has
menu-horizontal-foooter-eng
ID. It is generated automatically by WordPress based on the menu name.
The CSS you have on your site targets only #menu-horizontal-footer. You need to include CSS for #menu-horizontal-foooter-eng as well.
You can see the example below:
footer.main-footer .widget.widget_nav_menu #menu-horizontal-foooter-eng li {
    display: inline-block;
    vertical-align: top;
footer.main-footer .widget.widget_nav_menu #menu-horizontal-foooter-eng{
    text-align: center;
You can either add this CSS in style.css of your child theme or paste this in Appearance - Customize - Additional CSS.
Please note that we currently do not support custom work within the forum therefore the above code is just an example to point you to the right direction but if you need further customization we recommend contacting our 3rd party contractors https://wpml.org/contractors/
Let me know if you have any other questions!
