Last updated by Carlos Rojas 8 months, 3 weeks ago.
September 16, 2019 at 6:51 pm
florianV-6
The yellow text below should be German, not English! (see 1.jpg)
The original German text within Divi was located under Theme Customizer  Footer  Bottom Bar  Edit footer credits (see 2.jpg)
This was all German, now WPML has changed it automatically into English. This should not have happened. I had to change it all back into German!!! (see 3.jpg)
But in the string translation the German text is still shown as English, while the English text has no turned into German: (see 4.jpg)
Yet, the footer shows now German text on the translated English page as well as on the original German page: (see 5.jpg and 6.jpg)
WPML is doing crazy things. Please advise.
September 17, 2019 at 10:36 am #4587743
Carlos Rojas
Have you tried removing the footer string and it's translation -> Save the changes -> Make sure the text is removed from String Translation (delete the string from String Translation if necessary) and then adding it again?
Kind regards,
Carlos
September 19, 2019 at 7:33 am #4602001
florianV-6
I did as you said (deleted the string translation, and redid the whole thing) and it worked for a day, but now – again out of the blue – the German text is erased and overwritten with the English text, although the string translation still shows the correct German text (yellow) (see 9.jpg).
September 19, 2019 at 10:52 am #4603831
Carlos Rojas
I removed the string again and this time WPML fetched it in the wrong language, so I had to re-assign it to the correct language. Could you add the translation again and check if the issue disappeared?
Note: Please disable all Autoptimize plugins before doing the changes above.
Carlos
