Problem: Frontpage section for Hestia Pro still not working properly
Solution: The client mentioned that "THemeisle - About sections text is coming from the Pages (different from other Frontpage sections), so translating it on the page solved the issue."
Last updated by andraS 1 year, 4 months ago.
October 5, 2018 at 10:44 am #2790417
andraS
We have already one closed thread about my issue: https://wpml.org/forums/topic/hestia-pro-frontpage-sections-not-foundable-as-strings/ It looked first that it got solved but now after hestia pro update I realized that sections background image disappears, I can use only default image (ok that may be also theme issue) but also translation is missing for that section on the website, I can see translated string under String translations, there it is marked as "translated" as well. any suggestions what can i do?
October 8, 2018 at 11:47 am #2795873
Shekhar Bhandari
Hello there,
Could you please provide me login details, so I can quickly check the settings and provide you feedback? I need to request temporary access (wp-admin and FTP) to your site in order to be of better help. You will find the needed fields for this below the comment area when you log in to leave your next reply. hidden link
These info is private, and available to you and supporters only. Read more about this: https://wpml.org/purchase/support-policy/privacy-and-security-when-providing-debug-information-for-support/
Note that:
#1
Backup (both files and database) your site before giving us your credentials. You can use a plugin for this if you like. I often use the Duplicator plugin for this purpose.
See: http://wordpress.org/plugins/duplicator/
Duplicator instruction
It would be better if you give me the test site rather than the live site.
#3
If the issues needs some changes in the plugins updates/disabling we will install a plugin called “duplicator” and replicate the site in our local server for testing.
Look forward to your reply.
