Last updated by Rohan Sadanandan 10 months, 4 weeks ago.
Assigned support staff: Rohan Sadanandan.
July 9, 2019 at 9:06 am
matthewC-28
I'm trying to show the slider we have on our homepage on the translated versions (The slider doesn't need translating), but it won't show up on any translated page.
When i edit a translated page directly, i see the slider option is not selected, when i add it back in and save the page, these changes don't actually get saved.
The second issue is with the main menu, I have syncronised this however when i look at the menu items, they don't contain any links etc.
July 9, 2019 at 2:54 pm #4172139
Rohan Sadanandan
I just checked your site.
If you don't want to translate the slides you can set it as not translatable from WPML > Settings > Post Types Translation section
I would also suggest you read this dedicated page about the Avada theme: https://wpml.org/documentation/theme-compatibility/using-wpml-with-the-avada-theme/
The menu seems to be working fine.
Rohan
