This topic contains 11 replies, has 3 voices.
Last updated by Olivier 6 years, 5 months ago.
August 9, 2013 at 9:11 am #153287
Olivier
We have a problem with translation of gravity forms
we have one gravity form and in the label of a Radio buttons we have place a url (a link) in the choice label. These link are ok in the form of the main language page
When we go in the WPML Translation and select the form, all the box that contain a link are corrupted, non possible to mark them as completed and so not possible to complete the translation of the form.
The only possibility was to go in the mysql and remove manually all the link in the fields.
Olivier
August 9, 2013 at 5:27 pm #153472
Adriano
Dear Olivier,
Are you using the latest version of WPML + WP + Multilingual Gravity Forms? Can I see this page?
August 9, 2013 at 8:13 pm #153526
Olivier
last version of all
sorry i pass 1 h to find and remove manually in the DB all the url i dont want to try again 🙂
and another point that is strange is that when i see that i remove the url in the english main language correctly through the gravity editor, but when i go back to translation for the secondary language (where the boxes are corrupted) the english version mentioned in the bottom of the box still have the url in text !
(i have only my live install with this config WP + WPML + Gravity) and dont want to try again to include a url but it is very simple to try on a any non critical install.
August 9, 2013 at 8:51 pm #153536
Adriano
Dear Olivier,
Right, I will check it here.
August 12, 2013 at 4:21 pm #154067
Adriano
Dear Olivier,
Could you send me by email the Gravity Forms that you are using, put this thread URL in the subject's email? (adriano.f@onthegosystems.com)
September 4, 2013 at 9:17 pm #160959
Adriano
Dear Olivier,
My apologies for the big delay. Please replace your version with this development version and let me know if it has been solved: hidden link
September 5, 2013 at 12:31 pm #161240
Olivier
Sorry not solved
problem alwready there ...
September 6, 2013 at 1:22 pm #161681
Adriano
Dear Olivier,
Right, I see the problem. I've added it to our to do list to be fixed in the next beta release, I've also attached your ticket at it, so you will be notified when it is done. Thank you for your understanding.
September 9, 2013 at 11:17 am #219114
David
Dear Olivier,
Updated link hidden link with a fix. You can now translate option values containing urls just fine (though the 'Copy rfom English' link doesn't work)
Regards
Alvaro
September 9, 2013 at 12:24 pm #219163
Olivier
Hi Alvaro
Thanks it works now and the Box is correct and possible to save the translation but...
Just one point in that box the link "Copy from" the main language does not work (works for other box without url in the label) ...
This is not very important for me but could be a problem for others ....
Tanks a lot for your support
Olivier
September 10, 2013 at 7:45 am #219562
David
Yes, as in fact I mentioned in my message (but we are keeping coding changes to a minimun now so we are not changing it now). But you can select the text in the box 'Original conteny' below the field, and copy/paste.
September 10, 2013 at 9:54 am #219657
Olivier
absolutly ... not a problem for now ...
