Last updated by Itamar 9 months, 3 weeks ago.
August 1, 2019 at 9:09 am #4320063
laetitiad-2
Dear all
I have an issue on my optimisation website for the french and arabic version.
It works well on the english version.
As you can see on the comparison report hidden link
I woud like to know if there is something to do on the WPML side.
I use W3 Total Cache
Thank you for your help
Laetitia
August 1, 2019 at 10:26 am #4320549
laetitiad-2
yes thanks for your help
August 1, 2019 at 12:28 pm #4321621
laetitiad-2
Hi again
the issue is coming from the duplicate content
same content served by different URL
How can I avoid that ?
Laetitia
August 1, 2019 at 3:51 pm #4323655
Itamar
Hi, Laetitia.
Marcel is not available now so I'll continue to handle this ticket. I hope that it is alright with you.
The W3TC plugin is very powerful, but it is also quite complex for configuration. The W3TC is compatible with WPML.
Can you please confirm that you are following our instructions at the following link on how to work with WPML and the W3TC?
https://wpml.org/documentation/plugins-compatibility/optimize-multilingual-website-performance-using-w3-total-cache/
If you find that configuring this plugin is complex then please consider using another caching plugin. The WP Super Cache plugin is also compatible with WPML and is easier for configurations.
https://wpml.org/plugin/wp-super-cache/
https://wordpress.org/plugins/wp-super-cache/
Please let me know if this information is helpful to you.
Itamar.
August 1, 2019 at 4:07 pm #4323939
laetitiad-2
Thank you I have followed the W3TC guidelines and as you can see the test is good with the english version but not with the french version
but the problem I detected is the following one :
for exemple
in my GT metrix result test.amarencogroup will charge duplicate content from test.amarencogroup.com and testen.amarencogroup.com that's why I have a bad score.
Could you please advice how I can avoid this ?
Laetitia
August 1, 2019 at 4:34 pm #4324193
Itamar
Hi and thanks for the extra details.
You are using different domain per language like so:
French (default): hidden link
English: hidden link
Arabic: hidden link
I add this information because of your last reply where you mentioned that the same content loads from different URLs:
- hidden link
- hidden link
Can you please explain to me what these URLs are?
Can you please elaborate on this point and explain to me where I can see this on the GT Metrix result?
I want to add that I'm not sure that WPML causes this issue.
To test this can you please temporarily deactivate WPML. Now French should be the only language on your site.
Do you still get the same problematic results hidden link when WPML is deactivated?
If so, then it is probably not an issue that coming from WPML.
Please note that if you need further help from me, I'll be able to reply on Sunday.
Best Regards,
Itamar.
August 1, 2019 at 5:13 pm #4324453
laetitiad-2
Hi thanks again for you message
I prefer to focus on the test website that's why I mentionned these URL
- French (default):hidden link
- English: hidden link
instead of the official website
Arabic: hidden link
- without desactivating WPML here are the results :
French : hidden link ( scrore F27%)
English : hidden link ( score B 87%)
- when I desactivate WPML
French : score B 89%
English : score B 87%
When you check the result the problem come from
- serve ressource from a consistent URL
- defer parsing of javascript
You will see that for the french version includes both URL test.amarenco.com and testen.amarenco.com
I hope it is clear
Thank you again for your help
Laetitia
August 1, 2019 at 8:33 pm #4325065
laetitiad-2
Dear Itamar,
I have found the unswear on this post https://wpml.org/forums/topic/resources-are-loaded-for-both-of-my-languages-affecting-the-loading-time/
But now I wonder how it is possible to redirect the langage according to the langage navigator ?
Laetitia
August 4, 2019 at 9:25 am #4335969
Itamar
Hi and thanks for referring me to the other ticket.
I'm not sure that I understand the question that you are asking.
But now I wonder how it is possible to redirect the langage according to the langage navigator?
To disable the browser language redirect option, please do the following.
1. WPML -> Languages -> Browser language redirect.
2. Select the option 'Disable browser language redirect'.
3. Save the settings.
4. Check if the problem of the resources that are being loaded from the different domains are is now solved.
Please note that you would need to re-save the permalinks of your site. And please also clear the cache from your site.
Please read our documentation about browser language redirect here.
https://wpml.org/documentation/getting-started-guide/language-setup/automatic-redirect-based-on-browser-language/
Please also be aware that when this option is active, it can affect Google site indexing.
https://wpml.org/documentation/getting-started-guide/language-setup/automatic-redirect-based-on-browser-language/how-browser-language-redirect-affects-google-indexing/
Please let me know if this information helps you to understand the issue or you have any further questions about it.
Itamar.
The topic ‘[Closed] GT Metrix optimisation problem’ is closed to new replies.
