Last updated by Noman 1 year, 12 months ago.
Assigned support staff: Noman.
June 18, 2019 at 2:55 pm #4044591
jelleH-2
I am trying to: give the footer different content per language. This is not working for additional languages (German and Dutch). I noticed when editing footer, English has a different id, German and English having the same id. How to fix this? Template is using Elementor.
I expected to see: Able to use different footer content
Instead, I got: Same footer content for additional languages.
June 19, 2019 at 5:42 am #4048039
Noman
Thank you for contacting WPML Support. To take a closer look on this issue, please provide temporary access (WP-Admin and FTP Login info) to your site (preferably staging site), so that I can look into your setup and debug the issue.
✙ I would additionally need your permission to de-activate and re-activate Plugins and the Theme, and to change configurations on the site. This is also a reason the backup is really important.
Thank you
June 20, 2019 at 5:42 am #4056655
Noman
I have fixed this issue by doing below steps:
- Enabled Theme Parts (jet-theme-core) CPT translation from WPML >> Settings >> Multilingual content setup > Post Types Translation
- Duplicated Primary language Footer in secondary languages.
Now it’s showing correct footer in frontend as you can see in the attached screenshot.
You can add/update footer translation from here:
Please let me know if this resolves your issue or you need further assistance with this issue.
Thank you
