Last updated by cassidyO 10 months, 1 week ago.
Assigned support staff: Rohan Sadanandan.
July 30, 2019 at 2:23 pm #4308453
cassidyO
I have used ocean wp theme, on the page translation is well but Header and Footer not translated.
July 30, 2019 at 2:28 pm #4308495
cassidyO
Header and footer images
July 30, 2019 at 3:24 pm #4309157
Rohan Sadanandan
Please enable the Debug Information so that we can provide faster support.
Please go to WPML > Support > Debug Information and give me the information in the next reply. You can read the detailed instruction here: http://wpml.org/faq/provide-debug-information-faster-support/
The Header & Footer text strings are usually located in the String Translation.
Could you please navigate to WPML > String Translation & search for the strings there?
You can read more about String Translation here:
https://wpml.org/documentation/getting-started-guide/string-translation/
Also, maybe the strings you need to translate are among the admin texts, if this is the case you will be able to translate them by following the steps described in this link: https://wpml.org/documentation/getting-started-guide/string-translation/#admin_texts
Please let me if you have any doubts.
Rohan
July 30, 2019 at 5:03 pm #4309821
cassidyO
please check Debug information
Actually, I have created a header and footer custom template in elementor.
July 31, 2019 at 7:43 am #4312439
Rohan Sadanandan
Thanks for sharing the debug info.
You can read more about translating elementor by following the below link:
https://wpml.org/documentation/plugins-compatibility/elementor/
If you have any doubts, please let me know.
Rohan
July 31, 2019 at 8:07 am #4312627
cassidyO
Header and Footer Templates Already Translated But this not appears on the home page
July 31, 2019 at 12:58 pm #4314597
Rohan Sadanandan
I need to request temporary access (wp-admin and FTP) to your site - preferably to a test site where the problem has been replicated if possible - in order to be of better help. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Instructions to send private information are here: hidden link
Privacy and Security when Providing Debug Information for Support:
Also, please allow me to make a duplicator copy of your site using Duplicator plugin(https://wordpress.org/plugins/duplicator/) for debugging the issue on my local server.
Rohan
July 31, 2019 at 1:00 pm #4314609
Rohan Sadanandan
Sorry, I just enabled private reply for this message.
Rohan
August 1, 2019 at 6:21 am #4319029
Rohan Sadanandan
Thanks for sharing the access details.
Could you please share the link of the Header & Footer section?
I've found a Header & Footer in this link but the shortcodes are different from the screenshot you have sent:
This is just to make sure that I'm checking on the correct section.
Rohan
August 1, 2019 at 6:30 am #4319033
cassidyO
oceanwp theme my library : hidden link
August 1, 2019 at 2:32 pm #4322771
Rohan Sadanandan
I've successfully translated the Header & Footer.
The steps I've followed are given below:
1. Navigate to Theme Panel > My Library
2. Change the language using the admin language switcher on the top.
2. Note down the id in the Ocean WP shortcode for eg: if the shortcode is [oceanwp_library id="1837"], then take "1837"
3. Navigate to WPML > String Translations
4. Select the domain "admin_texts_theme_mods_oceanwp"
5. You can see the Header Template as [theme_mods_oceanwp]ocean_header_template and Footer template as [theme_mods_oceanwp]ocean_footer_widgets_template
6. I've changed these strings default language to English, so you can see the English value as 853 and 888
7. Click on Translations & enter the id for each language.
For eg., the German footer id is 1837
Similarly, I've updated all the 3 languages using the id I got from the shortcode.
You can read more about this in the Ocean WP documentation:
Rohan
August 1, 2019 at 4:04 pm #4323919
cassidyO
can you send me pics how to you fixed issue?
