Problem: Trying to translate some strings in the footer.
Solution: To translate widget titles in footer section please follow these steps:
- Here is doc for translating widgets: https://wpml.org/documentation/getting-started-guide/translating-widgets/
Or the other way, install and activate WPML String Translation: https://wpml.org/download/wpml-string-translation/
-- Then, go to WPML >> String translation >> Search for the string/title you want to translate >> Add a translation >> Check "Translation is complete” >> Save.
Our next available supporter will start replying to tickets in about 3.05 hours from now. Thank you for your understanding.
Last updated by oscarM-16 8 months, 3 weeks ago.
Assigned support staff: Noman.
September 3, 2019 at 4:04 pm #4506151
oscarM-16
Tell us what you are trying to do? Translate some strings
Is there a similar example that we can see? I opened a ticket, and found the string, but they does not work
What is the link to your site? hidden link
September 3, 2019 at 4:19 pm #4506201
Noman
Thank you for contacting WPML Support. Do you want to translate widget titles from footer section as you can see in the attached screenshot?
If you still find any issue please add the debug report in the Debug Information box. I have also enabled debug info box for your next reply: https://wpml.org/faq/provide-debug-information-faster-support/
Thank you
September 10, 2019 at 6:21 am #4542121
oscarM-16
