This topic contains 37 replies, has 3 voices.
Last updated by Mihai 8 years, 1 month ago.
Assigned support staff: Mihai.
May 28, 2013 at 5:22 pm #131020
ZE’EV
i installed your version .. it shows as v1.1
but the plugin panel says there is an updated v1.2 !?
should i ignore that?
May 28, 2013 at 5:28 pm #131022
ZE’EV
Ok I diffed your version and 1.2 and the only difference is the version tag
May 28, 2013 at 6:05 pm #131029
ZE’EV
Oh brother. The new importer successfully imported the posts and split them up.
BUT it did NOT import ANY of the secondary language (Hebrew) Categories or Tags.
Also, I have it set to "Display all posts (display translation if it exists or posts in default language otherwise)"
yet it ONLY shows posts in the selected language.
May 28, 2013 at 6:20 pm #131036
ZE’EV
AND it's showing Pages multiple times, not translated in menu ...
Look at
May 28, 2013 at 7:12 pm #131054
Mihai
You can ignore the version number. When I sent you the patched 1.1 version it included the fix that was then included in version 1.2 released shortly after.
I will look at the categories issue. You run the import on the clean database not on one that you may have attempted to run the import before, right?
"Display all posts (display translation if it exists or posts in default language otherwise)" - this only works (like it says there) with the standard blog page.
May 28, 2013 at 7:16 pm #131056
ZE’EV
Yes, I ran it on clean restored db, same as you used.
"this only works (like it says there) with the standard blog page." - what does that mean?
May 29, 2013 at 1:39 pm #131290
Andreas Neuber
Hello Zeev,
Has the WP login changed?
I'm trying to check the issue with your duplicate content.
May 29, 2013 at 6:51 pm #131367
ZE’EV
I recreated the account, try now
May 30, 2013 at 6:56 am #131460
Andreas Neuber
Perfect - works now.
I will collect all necessary data and get in contact with Mihai again.
May 31, 2013 at 11:19 pm #132005
ZE’EV
what's going on? this is taking forever ... site is busted ...
June 3, 2013 at 11:30 am #132360
Andreas Neuber
Hello Ze'ev,
Asked again for you:
Our developers are working on it. Please keep in mind that developers face the challenge not only to implement improved functionality but also to run several "cross-compatibility checks".
The newly added code should in no way break existing functionality. This is why solving issues like this often take a longer.
Since you have a database backup, we would recommend that for the time being you restore your site to the state before the import.
I will keep you update - thank you for your patience!"
June 3, 2013 at 12:18 pm #132383
Mihai
Ze'ev, Andreas will email you shortly a new version with a couple more fixes.
June 5, 2013 at 3:05 am #132954
ZE’EV
Well, now the cats/tags were preserved, but all the Hebrew ones have ZERO posts.
They were not applied to any posts.
I think I'm ready for a refund ...
June 5, 2013 at 6:08 am #132957
Mihai
I'm sorry you feel this way Ze'ev. We're trying to help you with everything you need here. This meant a lot of debugging and even adjusting the qTranslate import to your specific data that's not in a standard format like most of the databases for which this plugin works well.
I will be looking at the categories issue today and send you an update.
June 5, 2013 at 6:33 am #132959
Mihai
Sent you a new email with a new version including a fix.
