Last updated by Riffaz 4 months, 3 weeks ago.
October 1, 2019 at 1:28 am #4667905
adamB-42
Using Divi: Translating English to other languages
Please confirm or correct my understanding of these 2 options.
Skip Language - Will automatically duplicate every untranslated page. Adding a translation later will (replace, overwrite, or something like that) the existing duplicate?
Link to home of language for missing translations - no duplicates created - you get a translation if available or a home page if not (of the missing language)?
As for duplicates, as long as I only edit the English, the duplicates will update automatically to match, but if I mistakenly edit the duplicates, this automatic updating of duplicates will no longer work for future English edits?
So . . . I (using the skip option) edited the duplicates by mistake while trying to correct broken links. I have to much to update across all the duplicates as am actively developing the site. I deleted all 2nd language pages, but I cannot locate and delete the duplicates.
What can I do?
October 1, 2019 at 4:59 am #4668757
Riffaz
- if you choose this option language switcher will not displayed in page/post/etc which is NOT translated.
- yes, no duplicates.
- it will redirect to the correct translation if available. if no translation you will be redirected to the homepage.
- no, original will not get updated automatically
- if you do not have any page in second language how is this even possible to have a duplicate page in your site?
- clear your cache and check
- go to WPML > Support > Troubleshooting and perform all the buttons there except 'reset'
Riffaz.
