I am planning to change the settings and use only one domain, and use the "Different languages in directories" option.
However, if I make this change, people going to the secondary "unused domains" or following old URLs will see a 404 error.
I would like to redirect all the pages from my three domains to the specific "Different languages in directories".
Here is an example of the setup you need, assuming you have two languages:
- example.com - English - default language
- pl.example.com - Polish - second language
With your change, you should add the following block to your nginx:
server {
        #implemented by default, change if you need different ip or port
        #listen *:80 | *:8000;
        server_name pl.example.com;
        return 301 $scheme://example.com/pl$request_uri;
Relevant Documentation:
http://stackoverflow.com/questions/10294481/how-to-redirect-a-url-in-nginx
Last updated by Sergio 4 years, 6 months ago.
Assigned support staff: Dat Hoang.
December 8, 2015 at 3:16 pm #763799
Sergio
Hello, I hope you can help me. I have a site with 3 languages. One in each domain.
I am planning to change the settings and use only 1 domain, and use the "Different languages in directories" option.
However if I make this change, the people that will go to the 2 "unused domains" or that will follow old URLs, will see a 404 error.
I would like to redirect all the pages from my 3 domains to the specific "Different languages in directories".
Can you please help? If yes I can give the list of domains and how/where they should redirect.
Thank you
December 9, 2015 at 9:33 am #764415
Dat Hoang
I assume that you have 2 languages:
* example.com - English - default language
* pl.example.com - Polish - 2nd language
server {
        return 301 $<em><u>hidden link</u></em>;
Actually this is nothing related to WPML 🙂
Reference: http://stackoverflow.com/questions/10294481/how-to-redirect-a-url-in-nginx
December 24, 2015 at 12:05 am #775972
Sergio
Thank you
