Last updated by Andreas W. 9 months, 2 weeks ago.
May 13, 2019 at 2:52 pm #3799587
danielV-61
I was in the chat with you, I then even gave you my credentials and said that we need to launch the website today and need fast support, and then the ticket moved away from the chat and I don't even know what you changed on the website.
How should we proceed now?
Here's the description of the problem and the history:
https://wpml.org/forums/topic/translated-images-are-not-showing-in-translated-language/
Daniel
May 13, 2019 at 7:05 pm #3801295
Thank you for your message.
Did you try to applz the custom XML config that my colleague Laura provided on the above mentioned ticket?
This code will need to be added at WPML -> Settings -> Custom XML Config.
<wpml-config>
<shortcodes>
<shortcode>
            <tag>grve_single_image</tag>
            <attributes>
                <attribute>image</attribute>
            </attributes>
        </shortcode>
</shortcodes>
</wpml-config>
Once this snippet is applied please go to your page and give the original content an update. Then translate it again. The images should be translated now.
Let me know if this solved the issue.
Kind regards
The topic ‘[Closed] Help with translating images’ is closed to new replies.
