Last updated by George Botsev 5 years ago.
Assigned support staff: George Botsev.
May 18, 2015 at 6:31 pm #621021
ideaspace
I am facing a problem while translating home page title, home page description and meta keywords. I am adding the translation using the string translation panel. But it is not reflected on the frontend.
My website address is hidden link
Could you please help me on this.....
May 19, 2015 at 6:42 am #621240
Ankit
Hi rondaP,
Thank you for contacting support forum.
Can you please do following for me?
1. Ensure that Translation for the mentioned strings are marked as complete in String Translation module.
2. Deactivate all non-related wpml plugins and switch to default wordpress theme (Twenty Fourteen or Twenty Fifteen), check if similar issue persists or not?
// Note: Please take database backup before performing above mentioned step.
Let me know your response.
Regards
Ankit G.
May 19, 2015 at 2:11 pm #621757
ideaspace
Hi Ankit,
I have tried the steps you mentioned but it is not working for me.
Attached is the screenshot of the string translation page. Also i tried disabling all the plugins and switched to Twenty Fifteen theme.
But I still can't see the translations.
May 20, 2015 at 8:00 am #622269
Ankit
I would request you consider providing me with temporary access (wp-admin and FTP) to your site in order to be of better help.
You will find the needed fields for this below the comment area when you log in to leave your next reply (See attachment). The information you will enter is private which means only you and I can see and have access to it.
Regards
Ankit G.
May 20, 2015 at 12:24 pm #622560
Ankit
Thanks for providing the credentials.
I have escalated this issue to our second tier support team. They will handle this issue and will get back to you with further updates.
Thanks for your patience.
Regards
Ankit G.
May 22, 2015 at 8:13 am #624059
George Botsev
Timezone: Europe/Sofia (GMT+03:00)
Hello, I am George from second tier support.
I have found out the issue and I reproduced it.
It appears that currently we have problem with these translations, so if you specify a static string there - it is not getting translated. This will be resolved in WPML 3.2 when released.
However if you use the variables for these parameters instead (like in a default WordPress Seo setup) - because they are translated on other place - they will be translated.
As a second workaround, you may want to test our latest beta version - the issue might be resolved there. However I would recommend you to not use that version for production and wait for the release of the stable version.
The topic ‘[Closed] Home Page Title not changing not translating’ is closed to new replies.
