Last updated by laura-dY 1 year, 1 month ago.
Assigned support staff: Mihai Apetrei.
April 19, 2019 at 1:01 pm #3645843
laura-dY
I've created a custom post type: experts. Within this CPT, I have many custom fields using ACF. I had set the fields first_name and last_name not to translate, but I should have set it to copy. I've changed that now, but the fields don't show up when I edit a translation and they don't show up on the front end. How can I get these new settings to apply? Do I have to go into every expert post and add those fields manually?
April 19, 2019 at 1:30 pm #3646079
Mihai Apetrei
Hi and thank you for contacting WPML Support!
I will be happy to help you with this.
You would need to save both the original language post and the translation, too. If you don't save the original, the "copy" command is not triggered.
Hope this is helpful 🙂
Kind regards,
Mihai Apetrei
April 19, 2019 at 1:43 pm #3646139
laura-dY
Ok, so re-saving the default language version isn't enough to copy the fields over? I have to go in and manually save every post in both languages?
Also, these fields won't show up in the translation screen correct? Only fields set to translate will show up there? (I thought they might show up but not be editable).
April 19, 2019 at 4:00 pm #3647391
Mihai Apetrei
- Yes, you are right!
- Yes, you are right. Selecting "Copy" should copy the custom field and keep it in synchronization with the default language content while using "Copy once" would just copy the custom field only once but then it would allow you to change the content
You can see it explained here, too (at the bottom):
I hope that you will find this information helpful 🙂
Just a note that I won't be working on the weekend so I will be able to get back to you at the beginning of next week in case you need more help with this.
Kind regards,
Mihai
April 23, 2019 at 6:49 am #3659805
laura-dY
