You are using WPML CMS license but want to avoid the Translation Management flow.
Translation Management is an integral part of WPML and cannot be disabled. However, you can choose not to use it by cancelling all current translation jobs and translating directly within the posts/pages edit screens. For translating content, follow the steps outlined here: Using plus icons to translate content.
Additionally, with your Multilingual CMS license, you can utilize the Advanced Translation Editor for automatic translations, accessible here: Advanced Translation Editor. We advise against downgrading your license as it would limit your ability to translate strings from your theme or other plugins and access to automatic translations.
If this solution does not apply to your situation, or if it seems outdated, we recommend opening a new support ticket. We also suggest checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum: WPML Support Forum.
Last updated by Otto 1 month, 1 week ago.
Assisted by: Otto.
March 18, 2025 at 3:33 am #16827720
benR-23
I am trying to use WPML in a simple way for my website, which is a hobby project. I write posts in English, translate them automatically, edit the translations, and then update the original text to repeat the cycle. I am a writer and translator, and I want to understand the constraints of WPML. My website has little or no custom code.
I have a queue of translation jobs that is unclear to me. The last time I tried to update the automatic translation of a page into Spanish, the formatting was messed up, and the translation was incomplete. The previous version was okay, but after editing the original text, the automatic translation did not work as expected.
How to do without translation management?
How to correct the most recent translation?
Is translation management possibly causing this problem?
What if I delete the entire queue of translation jobs?
Is it possible to turn translation management off?
March 19, 2025 at 4:29 pm #16836529
Otto
WPML Supporter since 09/2015
Translation Management is part of WPML Core and can't be disabled. But you can avoid using it.
You can cancel all current translation jobs and translate directly in the posts/pages edit screens.
You can translate following this flow:
https://wpml.org/documentation/getting-started-guide/using-plus-icons-to-translate-content/
As you have the Multilingual CMS license you can use the Advanced Translation Editor:
https://wpml.org/documentation/translating-your-contents/advanced-translation-editor/
which will allow you to translate automatically.
Although you won't be using the Translation Management feature I do not recommend downgrading your license to Blog, because you won't be able to translate strings from your theme or other plugins. And you won't have automatic translations.
Best Regards,
Otto
