Last updated by Christopher Amirian 3 years, 3 months ago.
| Author | Posts |
| January 25, 2023 at 6:49 pm #12893099 | |
Digital Marketing Team |
Tell us what you are trying to do? Is there any documentation that you are following? Is there a similar example that we can see? Incorrect styling when viewed in translated language (columns and title colors are different) - hidden link What is the link to your site? |
| January 26, 2023 at 6:15 am #12894941 | |
Christopher Amirian WPML Supporter since 07/2020
Languages: English (English ) Timezone: Asia/Yerevan (GMT+04:00) |
Hi there, It seems that you use a plugin called Max Megamenu for the menu. I checked and we did not test that plugin with WPML, but they created documentation that might help you here: hidden link Thank you. |
| January 26, 2023 at 9:55 pm #12900475 | |
Hi Chris, If you read my response I had already listed that link / documentation. Unfortunately it does not resolve my issue with being able to duplicate the styling. Do you have any other suggestions? |
| January 27, 2023 at 10:19 am #12903125 | |
Hi there, No, unfortunately, I'd appreciate it if you can share that with the Max Mega Menu developer as they claim that they are compatible with WPML. Meanwhile, I can report this to the compatibility team to see if there is a solution available. To do that we need to replicate the issue on a clean installation. I created a clean installation that you can access here: hidden link Please install the Max Mega Menu plugin there and create a simple menu with some styling, then try to translate that menu. If the issue is there then I can ask the compatibility team to take a look into that. So you have a two-tiered approach, one from the Max Menu developers which will be your main course of action and another one a possible solution from our side (not guaranteed). Thank you. |
