Placing the language switcher in the top bar I was not able to show it horizontal. It takes too much space showing it vertical. On my current project I'mm using just 2 languages.
Add this CSS:
.elementor-location-header .elementor-element-populated .elementor-nav-menu li.wpml-ls-item {
    display: inline-block;
to the Appearance → Customize → Additional CSS area to make the language switcher be displayed on the same line.
Last updated by rosmarieF 2 years, 3 months ago.
Assigned support staff: Radu.
June 27, 2019 at 10:59 am #4099383
rosmarieF
Placing the language switcher in the top bar I was not able to show it horizontal. It takes to much space showing it vertical. On my current project I'mm using just 2 languages.
sub.profiwebmedia.com
Thank you for your support
June 27, 2019 at 11:19 am #4099557
Radu
Hey Rosmarie,
Can you add this CSS:
to the Appearance → Customize → Additional CSS area and tell me if the language switcher look better now, please?
Radu
June 27, 2019 at 12:31 pm #4100001
rosmarieF
Hello Radu,
thank you now it looks good in the default language. How to get it fixed also in the second language Italian? Thank you
June 28, 2019 at 7:01 am #4104953
Radu
Hey Rosmarie,
I checked the Italian version of the page and the language switcher looks like the one from English. Can you send me a link to a page where the language switcher is looking different, please?
Radu
June 28, 2019 at 8:19 am #4105473
rosmarieF
Hi Radu,
the problem persists only on mobile (smartphone) devices in the Italien version. German version was ok after you sent me the css code.
Thank you
Rosmarie
June 28, 2019 at 9:20 am #4105927
Radu
Hey Rosmarie,
Both German and Italien versions look the same on my side when checking the website on mobile (please see the screenshots).
Can you attach some screenshots from your mobile device so I can see how things look for you, please?
Radu
June 28, 2019 at 10:09 am #4106415
rosmarieF
Hi Radu, we tested it on 3 different smartphones. On 2 of them it looks like the attached screenshot, but only the Italian version, the default German version is ok.
Smartphone brand is Samsung and Xiaomi 5 inch. On a new Samsung 9+ it is displayed correctly.
June 28, 2019 at 10:39 am #4106635
Radu
Hey Rosmarie,
Can you tell me what's the browser that you're using, please? This may be related to the browser and I want to make sure that I'm using the same one to see what can be done about it.
Radu
June 28, 2019 at 12:11 pm #4107223
rosmarieF
We ow tried different browser and we see that it works with firefox for smartphone and with the browser which by default is installed on Xiaomi Smartphones.
But it does'nt work in Chrome and it doesn't work in Safari
Kind regards
Rosmarie
July 1, 2019 at 9:20 am #4116885
Radu
Hey Rosmarie,
Can you tell me if you moved the website from sub.profiwebmedia.com, please? I was gonna test it on Safari but it's no longer loading, no matter what browser I'm using.
Radu
July 1, 2019 at 9:49 am #4117435
rosmarieF
Hello Radu,
yes, sub.profiwebmedia.comn was our developing domain, last week we moved to hidden link
July 1, 2019 at 9:51 am #4117537
rosmarieF
Can you please tell uas how e can manage our domain licences? We have licences for 3 domains. Can we change our developing domain to another?
July 2, 2019 at 2:44 pm #4128043
Radu
Hey Rosmarie,
I checked again your website using Chrome and Safari and everything looks fine, no matter what language I'm checking. I tried to change the language, refresh the page, check some other pages, but nothing makes the language switcher look wrong. As I understand from one of your previous messages, you see this issue when using Samsung S9+ using Chrome, am I right? I'm asking this because I can use this device on my side but I wanted to make sure that I understand exactly what you said.
Regarding the licenses, of course you can stop using it for the developing domain and move it to a different one. There's no point in using a license for a development site. All you have to unregister the dev site through Dashboard → Plugins → Add new → Commercial tab and register the new domain.
Radu
July 2, 2019 at 3:38 pm #4128487
rosmarieF
Thank you Radu,
great.
Regarding the correct view of the switcher:
It does not work with Chrome and it does not work with Safari
if you use a smartphone with a 5" display.
May be, if you use a larger one, i.e. 5,5" it should work.
Kind regards
Rosmarie
July 3, 2019 at 9:40 am #4134087
Radu
Hey Rosmarie,
Can you tell me what's the device that you're using with Safari, please? I checked this browser on my laptop and the language switcher is displayed in just one line (see the attached screenshot).
Radu
