Last updated by Bruno 1 year ago.
April 26, 2019 at 3:17 pm #3691961
suleymanK
i read the old topics but couldn't put language switcher in top right corner?
April 26, 2019 at 11:42 pm #3693559
Bruno
Hi.
Thanks for contacting us. It depends on how the theme is created. What is the URL of your site? Exactly where do you want to add the language selector?
April 26, 2019 at 11:45 pm #3693561
suleymanK
I want to put it instead of the red button (Randevu Al)
April 26, 2019 at 11:46 pm #3693563
Bruno
Thank you. I'll need to request temporary access (wp-admin and FTP) to your site - preferably to a test site where the problem has been replicated if possible - in order to be of better help.
Note:
*** Please, can I install the Duplicator plugin (or All in One Migration) to make a copy of your site and install it on my test environment? This will help me debug the problem.
*** Note: Please make a full backup of your site.
Privacy and Security when Providing Debug Information for Support: https://wpml.org/purchase/support-policy/privacy-and-security-when-providing-debug-information-for-support/
April 27, 2019 at 11:29 am #3695305
suleymanK
Any news? Thanks.
April 29, 2019 at 7:28 am #3700545
suleymanK
April 30, 2019 at 1:02 am #3707067
Bruno
Sorry for the delay. On weekends I did not work.
When I try to access your site, this message is displayed: ERROR: Invalid username or password.
Please, could you check? If necessary, you can edit your credentials in your private message above, which is displayed highlighted.
April 30, 2019 at 9:26 am #3710041
suleymanK
Hi Bruno,
i fixed it. Please, try the information above again. You should be access..
April 30, 2019 at 5:05 pm #3713831
Bruno
Thank you. I'm not sure if it's possible to add the language selector in the location you want without much custom coding. It looks like you'll need to edit the header.php file for your theme to include a call to the language selector.
Unfortunately, the FTP information also seems to be incorrect so I can not see the files of your theme.
It looks like your theme will need to use a WPML action so that the language selector is displayed in the location you want: https://wpml.org/documentation/getting-started-guide/language-setup/language-switcher-options/#using-php-actions
If you that I check, please check the FTP credentials so I can look at the files of your theme.
April 30, 2019 at 5:09 pm #3713839
suleymanK
i updated the informations. Please check it again. By the way i use directadmin panel so you can use panel as well.
April 30, 2019 at 5:54 pm #3713975
Bruno
Thank you. I added the language selector to your specification. Note that I have added the code below into the file wp-content/themes/petro/template-part/top-bar.php
<?php do_action('wpml_add_language_selector'); ?>
Please, let me know if I can help with any other questions you may have about it. I'll be happy to help.
April 30, 2019 at 6:01 pm #3714009
suleymanK
The facebook and instagram icons and links disappeared in top left corner on mobile but it is ok, i ll fix it.
Thank you so much Bruno for the best support! Many many thanks.
April 30, 2019 at 6:08 pm #3714017
Bruno
Glad to hear that it now works. Note that I have added some CSS in WPML> Languages > Additional CSS also to set the language selector.
