Problem: If the customers come to visit the German site, and they want to move to front page again, they would click "home" button, but page does not go to home written in English
it stay there as German site.
Solution: The cause of this issue is that the Pages are set to be not translatable. To change this you need to go to WPML -> Settings -> Post Types Translation -> Set Pages to 'Translatable - only show translated items' -> Save the changes.
Then go to Pages and make sure the pages are correctly connected with their correspondent translations.
Relevant Documentation:
This topic contains 23 replies, has 3 voices.
Last updated by goodok 8 months, 4 weeks ago.
May 6, 2019 at 6:16 pm #3751997
goodok
My issue is that when I click the "home" button, I can not move to home page (front page)
when you see the some page written in German, there is a drag and drop button for multi-language.
in other words, hidden link ->www.com (as a hompage)
but it moves hidden link ->www.com/de (as a result, it does not move)
above site is not mine, just an example
I don't know about programming. if possible, I want to correct a little
May 6, 2019 at 8:15 pm #3752533
Carlos Rojas
1.- I would like to request temporary access (wp-admin and FTP) to your site to take better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Our Debugging Procedures
2.- Please increase the PHP Memory Limit. Minimum requirements are 128Mb: https://wpml.org/home/minimum-requirements/
/** Memory Limit */
Kind regards,
Carlos
May 6, 2019 at 10:03 pm #3752833
goodok
I did not back up my file yet. your time zone and my time zone is different. and when I just agree WordPress / server access, will you fix my issue? what is the next step?
May 7, 2019 at 10:17 am #3756295
Carlos Rojas
In my previous message I asked you to share access to the site so I can take a closer look at the issue and see if there are any errors in the debug.log.
If you desire you can activate the debug mode on the site by following the steps described in this link: https://codex.wordpress.org/Debugging_in_WordPress and let me know if there is any message in the debug.log file within wp-content folder.
Note: Please create a full backup of the site before making any change and go to Settings -> Permalinks -> Re-save the permalink structre.
Could you tell me the result of the steps above?
Carlos
May 7, 2019 at 3:46 pm #3759997
goodok
how can I make you can get WordPress / server access so that you can troubleshoot the problem? could you let me know? I can not activate the debug mode by myself. thank you
May 8, 2019 at 10:45 am #3765683
Carlos Rojas
Carlos
May 9, 2019 at 12:58 pm #3776261
Carlos Rojas
I tried to log in the site but the credentials didn't work. Please double check the credentials provided and edit your previous message if necessary.
Carlos
May 9, 2019 at 4:35 pm #3778109
goodok
Hi, thank you. I check it twice. but there's no prolem
I am using Bluehost. this is the log in address
using the id "greengrass.online", you can login
thank you ^^
May 9, 2019 at 11:27 pm #3779823
Carlos Rojas
Thank you very much for this new information.
This time I was able to log in the site. Before we continue I need to ask you to update all outdated plugins and themes, specially WPML plugins. Outdated functionalities can cause conflicts in the code.
Note: Please don't forget to create a full backup of the site before making any change.
Please let me know if the issue persists after the steps above.
Carlos
May 10, 2019 at 7:39 pm #3787693
goodok
Hi thank you
I solved one issue and there is other issue happened
as you said I updated WPML and activated WPML Multilingual CMS
and then I can move from "www.com/de"(written in German) ->"www.com" (home page)
but when I get to 'www.com" home page like above, language switcher in the main menu has gone. so I can not move to any other multilingual site
if you want I can give you an access to my site again
thank you
May 13, 2019 at 1:44 pm #3798969
Jamal
Carlos is not working today. If you don't mind, I'll continue with you on this ticket.
Yes, please provide access to your website so I could check this further.Please make sure to have a database backup.
Jamal
May 13, 2019 at 6:47 pm #3801231
goodok
thank you but in that case, I have explain it again. someone doesn't understand what my issue was. if carlos doesn't mind, I want him to continue again. thank you. have a nice day.
May 14, 2019 at 11:05 am #3806173
Jamal
Carlos is currently on vacation and would be back on Monday.
If you want to wait for him, I'll write to him about this and he will take care of the ticket on Monday. If you want us to continue with you, it would be my pleasure to help.
Jamal
May 14, 2019 at 4:13 pm #3809069
goodok
Hi there. No offence. I will wait carlos until he comes back. Please, let him know. when I have to explain my issue, It could be bothering. eventhough my Engish is not perfect, I think carlos could undetstood my words and he will fix my issue. anyway, thank you have a nice day.
May 14, 2019 at 6:07 pm #3809827
Jamal
Sure 🙂
I'll write to him. Have a nice day as well.
Jamal
