Problem: Meta Options missing within post editor on Dante theme Solution: Make sure to set all the custom fields (such as sf_thumbnail_link_type) to translate. You can control them on the posts directly.
Last updated by robertoB-13 4 months, 2 weeks ago.
Assigned support staff: Bruno Kos.
October 4, 2019 at 8:03 am
robertoB-13
I am trying to: change heading options and sidebars in translated posts and pages
Link to a page where the issue can be seen: see screenshot p3
I expected to see: hidden link
Instead, I got:
October 4, 2019 at 8:58 am
October 4, 2019 at 10:03 am #4694667
Bruno Kos
This has been escalated to our Compatibility team and may take some debugging time, I'll get back to you as soon as I have any news or questions for you.
Bruno Kos
October 7, 2019 at 12:54 pm #4707427
Bruno Kos
Can you check this?
It seems like this is up to how these main custom fields are being set. For example, if you set them to "Translate", then they will show up. If you select "Copy", they will copy, "Copy once" will allow you to change them, but will copy their value upon translation creation.
I cannot tell you for 100% which one belongs to which group, but you can do this by testing yourself - you select the preference of each of these custom fields and then you click apply, update the post and then you can see that they should show up (or get hidden), based on what you choose.
You need to do this on one post only and it will be applied globally.
Bruno Kos
October 7, 2019 at 1:59 pm #4708013
robertoB-13
Thank you Bruno.
Now I can manage the sidebars again, but I still can't control the Fancy Heading Background Image. As you can see from the screenshots in a is what I see in the italian translation and in b what I see in English. I've searched in the custom fields but it seems is not there the option. I don't know what happened: before last Monday everything was working fine.
R
October 9, 2019 at 9:44 am #4721439
Bruno Kos
I asked our compatibility team what could it be, because I wasn't able to find the custom field either, not sure why isn't it showing up.
Bruno Kos
October 10, 2019 at 1:23 pm #4730849
Bruno Kos
Can you check now? I registered a custom field to be translatable, but which is not registered in the options below for some reason.
Bruno Kos
October 10, 2019 at 2:12 pm #4731455
robertoB-13
Hi
yeah it's working fine now! Thank you!
But what did you exactly do? I'd like to know it just in order to do it by myself it it happens again.
October 11, 2019 at 7:20 am #4735937
Bruno Kos
If you check here, you will find some XML code:
It is about this:
https://wpml.org/documentation/support/language-configuration-files/
For example, the thumbnail link type has the following custom field: sf_thumbnail_link_type (you can see within the image how to get this value - you need to use chrome inspector to see it)
And then inside our XML configuration, in order to make this translatable, you add something like the following:
 <custom-field action="translate">sf_thumbnail_link_type</custom-field>
However, now that all these are in place, they will be applied globally and you should not worry about it anymore (unless theme developer ads new ones as they update these options).
Bruno Kos
October 11, 2019 at 7:38 am #4736055
robertoB-13
Thank you Bruno. Have a good weekend
Roberto
October 11, 2019 at 7:41 am #4736131
robertoB-13
It took 10 days to solve the problem, anyway my issue is resolved now. Thank you!
