Last updated by edens 10 months, 1 week ago.
August 24, 2019 at 2:11 pm #4451917
edens
Hello my friend,
I am using your plugin WPML and also using woocommerce product addons.
I have a problem in some of my forms with the russian language.
the problem happens when a customer try to add self customized sentence and he should be charged by small amount,
the amount should be 5$ by russian rubble (about ₽340 )
The problem is that my client is being charged of very high amount-about 21,000₽.
I have added here 2 screenshots so you will understand the difference between my main language(English) and my translated language (russian)
thank you and waiting for your update
August 25, 2019 at 5:11 pm #4454797
Bigul
Welcome to the WPML support forum. I will do my best to help you to resolve these issues.
I would like to access the admin area of your site for further checking. Please fill the private details fields after a full site backup.
Please check the following links for more details about our private information sharing policies.
Bigul
August 26, 2019 at 1:07 pm #4459025
Bigul
Thank you for the login information. I have a doubt about this. How you are managing/linking the *What should we write for you on the other side?* feature with a Product. Because I am not able to find the settings exactly.
Bigul
August 26, 2019 at 1:15 pm #4459125
edens
well,
I am manging it through
Products>Custom product options>then i choose any form i want to change>then i am in the form page and i can make changes there.
The thing is,
If you want to make a change in another language (russian for example), then the plugin limits you to make changes only by translation and not in other options (change price for example), since the major changes in the form should be changed from the english language form.
August 26, 2019 at 6:50 pm #4460885
Bigul
Thank you for updates. I have already gone through the Products>>Custom product options, but the English posts are showing in Hebrew. So please share me a couple of screenshots for a better understanding of the Product -> Form settings. Including the pricing settings.
Bigul
August 26, 2019 at 7:06 pm #4460927
edens
Hello, so for instance i have gone to a product form called:
טופס חריטה למצתים 2 צדדים
And i click on the edit section, then as you can see in the screenshots i can edit the price (5 in the screenshot),
But when you switch to russian language with russian rubble currency,
the amount is not equal to 5$ (you can see in the screenshot).
The specific form i have given you for example is the one that affect the lighter product in the picture,
I will also give you the product URL:
August 27, 2019 at 12:21 pm #4466415
Bigul
Thank you for the details. It looks like a compatibility issue. Please try the following troubleshooting steps after a site backup and make sure the issue is existing or not.
1) Go to WPML>>Support page
2) Click on Troubleshooting link (blue link in the middle of the page)
3) In Troubleshooting page, please click on the following options of the *Clean up* section. Wait for confirmation of processing after each one.
- Clear the cache in WPML
- Fix element_type collation
- Set language information
- Fix WPML tables collation
- Fix terms count
- Fix post type assignment
- Recreate ST DB cache tables
If the problem is existing, to debug the issue further without affecting your live site I have created a test site in our Sandbox server. It is a fresh/basic installation. Please visit the following URL and check the bug is reproducible or not.
Please try it with only the relevant plugins and theme. It will help us a lot and we can send it directly to our developers for further debugging.
Bigul
August 27, 2019 at 6:27 pm #4469121
edens
I have decided to put the USD currency in the russian language because it made me too much problems also with the payment page
