Last updated by aymanb-4 1 year, 11 months ago.
August 25, 2019 at 12:22 pm #4454027
aymanb-4
This problem occurs approximately every week
Your support team fixes it
But after a week or several days the problem returns again
August 26, 2019 at 8:01 am #4456589
Yvette
Hello
I will need more information about the nature of the issue.
1. Technical Information on you environment
Could you please provide information about your environment by following thsese steps: http://wpml.org/faq/provide-debug-information-faster-support/
2 Screenshot or log notifications
Please upload a screenshot of the issue or include an error message from the log. What is the nature of the problem?
August 26, 2019 at 7:08 pm #4460995
aymanb-4
i cant open anything , only c panel
i need live support please
August 26, 2019 at 7:41 pm #4461071
Yvette
This is asynchronous support. You might try the Chat support feature on the forum as my responses will happen with a delay.
1. Activate WordPress debug
If you cannot access your site, then you should activate the WordPress debug mode by editing the wp-config.php file and adding the line
define( 'WP_DEBUG', true );
You may get more information about the problem from the notifications that are generated.
2. WPML
However, if this is happening continuously, are you sure that the issue is with WPML? If you manually deactivate WPML, is the site accessible again?
You can manually deactivate a wordpress plugin by going to your plugins folder using Cpanel and temporarily renaming the sitepress-cms directory to be something else. e.g. x-sitepress-cms
3.Recurring issue
If the problem is recurring, you should also seek the support of your hosting provider who has access to server logs. A problem with the software would happen all the time. A problem with the server woudl be resource related and tend to happen intermittently as you described.
August 26, 2019 at 7:44 pm #4461075
aymanb-4
i sent the Technical Information
August 27, 2019 at 9:53 am #4464595
Yvette
Hello
THank you for this but I need to see the WORDPRESS DEBUG log notices to help you. Add the line to your wp-config.php
Did you try reaching out to your hosting support? This forum is more suitable for problems directly related to the code for WPML CMS plugin and not for general WordPress installation problems.
August 27, 2019 at 6:35 pm #4469139
aymanb-4
it is true From before
August 27, 2019 at 7:16 pm #4469213
aymanb-4
please i need the live chat support
August 28, 2019 at 8:56 am #4472573
Yvette
Please close this ticket and reopen a new one in the chat support. This forum is asynchronous support and will not meet your needs.
Be prepared to provide FTP and CPanel access to the supporter who you chat with.
In the meantime, to restore access to your site, follow these steps to manually deactivate the sitpress-cms directory .
- Log in to your site via FTP. ...
- Navigate to httpdocs > wp-content > plugins.
- Find the folder for the plugin that you need to disable.
- Right click on the plugin folder and select Rename.
Rename the plugin folder to disabled.[pluginname].
August 31, 2019 at 9:25 pm #4491485
aymanb-4
