Last updated by Bigul 1 year, 1 month ago.
April 1, 2019 at 5:52 pm #3510589
thomas lambelin
Hello
I use plugin Directories Pro from Sabai to create a listing on my site and WPML to translate the site.
For most of it I have no problem to translate the plugin which was sold as compatible with WPML.
But I have 2 problems :
- I can't translate (or I dind't find where) the html fileds I create in my directories (the html fields that are common to all the directories, I have no problem with the ones that change in the different directories).
- when I create an url field, I can't translate the text that is clickable instead of having the whole link, ie. : I have links that should be "online booking" instead of showing the whole URL. I can't translate this text neither.
Can you help ? or is it a problem on Directories Pro's side ?
Thank you
Regards
April 2, 2019 at 7:38 am #3514427
Bigul
Welcome to the WPML support forum. I will do my best to help you to resolve these issues.
For your kind information, *Directories* plugin is not listed on the WPML compatibility list for the Plugins - https://wpml.org/documentation/plugins-compatibility. It does not mean that this plugin is not compatible with WPML, but our compatibility team has not tested it yet.
Please share me a couple of screenshots for a better understanding of the issue.
Bigul
April 2, 2019 at 1:31 pm #3517693
thomas lambelin
Thanks. I upload screenshots today.
For info : It is not your fault but Directories Pro says it is compatible with WPML as you can see on screenshot.
April 2, 2019 at 5:33 pm #3519531
Bigul
Thank you for the updates. I would like to access the admin area of your site for further checking. Please fill the private details fields after a full site backup.
Please check the following links for more details about our private information sharing policies.
Also please share me the URL of the page you are having the issue.
Bigul
April 3, 2019 at 4:40 pm #3528811
Bigul
Thank you for the login information. Please check the attached images. Hope you are trying to translate these strings.
Please try the following steps after a backup and make sure you are getting the expected result or not.
1) Visit WPML>>Theme and plugins localization
2) Scroll down to *Strings in the plugins* section
3) Choose the plugin
4) Scan for the plugin strings
5) Visit WPML>>String Translation
6) Search for the missing strings
Bigul
April 3, 2019 at 5:13 pm #3529231
thomas lambelin
Yes. These are the strings I want to translate.
I have followed step by step your advices but this doesn't work.
These strings still don't appear in the string to be translated.
April 4, 2019 at 4:52 am #3532075
Bigul
Thank you for the updates. It requires further checking. So please allow me to make a duplicator copy of your site using the Duplicator plugin(https://wordpress.org/plugins/duplicator/) for debugging the issue on my local server.
Bigul
The topic ‘[Closed] I have problem with some translations from plugin Directories Pro (from Sabai)’ is closed to new replies.
