Last updated by Itamar 1 month, 1 week ago.
February 25, 2020 at 1:24 pm #5562659
albaB
The dropdown list showed in the attached image is not showed on my current installation.
February 25, 2020 at 2:49 pm #5563319
Itamar
Hi and thanks a lot for reporting this issue.
I can see it also on my test site with all the latest versions of WPML and its add-ons.
But the language dropdown list is not completely disappeared in my case. I can see it at the bottom of the screen. Please see the attached screenshot.
Do you also see it there?
In any case, we have a workaround for this issue. Here it is.
1. In Settings -> Permalinks insert the slug's base in the language that you need.
2. Go to WPML -> String Translation.
3. Search for this slug. It will be available under the WordPress domain. The Name, for example, will be URL product_cat tax slug if it is the product category.
4. Select this string and change its language.
5. Go to WooCommerce -> WooCommerce Multilingual -> Store URLs and translate the slug.
I've escalated this issue to our second tier supporters and they will report it to our developers.
I'll keep you updated here on any news regarding this issue.
Thank you for your patience.
Itamar.
February 25, 2020 at 4:39 pm #5564775
albaB
thank you for your help, but it is not working.
1.- Yes, I see the dropdowns on the bottom of the page, but if I select "spanish" and click "save", it automatically, turns to English again.
2.- I have translate it on string translation and in Store Urls, but it does not work. The slug for product base is the same in English and Spanish (is the one included on String Translation)
February 26, 2020 at 4:02 pm #5572771
Itamar
Hi.
You wrote: "1.- Yes, I see the dropdowns on the bottom of the page, but if I select "spanish" and click "save", it automatically, turns to English again."
This makes me think that you didn't follow my instructions correctly. I'm sorry if they were not clear enough. You shouldn't select 'Spanish' in Settings -> Permalinks. You should only insert the Spanish slug in the field (even if it shows that it is English. Then proceed with steps 2-5. For step 4 please read our documentation here.
https://wpml.org/documentation/getting-started-guide/string-translation/#original-language-of-strings
Can you please try it this way and see if it works for you?
BTW, we have an errata page published concerning this issue. Please see it here.
https://wpml.org/errata/woocommerce-multilingual-change-language-of-product-slug-base-language-switcher-option-is-at-the-bottom-of-the-page-instead-of-the-correct-place/
February 27, 2020 at 10:24 am #5577127
albaB
You are right, I didn't understand step 1. But, now, I have done every thing again and it still not working.
My original language is spanish and I want English translations.
So:
1.- in Settings -> Permaliks my product slug is "/producto/ "
2.- in WPML -> String Translation I set the language of the string "producto" to Spanish.
3.- in WooCommerce -> WooCommerce Multilingual -> Store URLs I have translated the slug.
I attach 3 screen shots
February 27, 2020 at 8:20 pm #5580905
Itamar
Hi.
I can see this problem on your site.
Can you please let me have access so I can check the issue?
I'm enabling a private message for the next reply.
Privacy and Security Policy
**IMPORTANT**
- - Please make a backup of site files and database before providing us access. --
Itamar.
The topic ‘[Closed] I have problems translating "product base"’ is closed to new replies.
