The client was experiencing issues with translating a WooCommerce composite product into Italian using WPML. The translation process was not functioning correctly, sometimes affecting the default English product as well. Specifically, when scenarios were added to composite products, the component dropdown options were not displaying correctly in the Italian version, though they worked fine in English.
We advised the client to ensure that all plugins were up to date and to use the Advanced Translation Editor (ATE) for translating products. It was important to translate using ATE rather than the WordPress Editor to avoid issues with saving changes and to ensure the translation process was handled correctly by WPML. We also suggested translating the products step-by-step using ATE and checking if the issue persisted. If problems continued, we recommended deactivating the WPML plugins temporarily to verify if the issue was indeed related to WPML or if it was an issue with the WooCommerce Composite Products plugin.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket here.
Last updated by Carlos Rojas 8 months, 1 week ago.
Assisted by: Carlos Rojas.
January 20, 2025 at 7:01 am #16611801
Carlos Rojas
WPML Supporter since 03/2017
Hi Mario,
Good morning 🙂
I would like to be able to deactivate the WPML plugins in the production site and double-check if the scenarios are working.
Note: The alternative is to restore the staging site into the production site and double-check if everything continues working correctly.
January 20, 2025 at 10:15 am #16612431
marioG-45
Hi Carlos,
Yes you can check on production site by deactivating wpml plugins for scenarios issues.
January 20, 2025 at 10:26 am #16612460
Carlos Rojas
Please confirm you have a full backup of the production site that you can use to restore the site if necessary.
January 20, 2025 at 10:54 am #16612683
marioG-45
Hi Carlos,
Yes I have the latest backup of the site.
You can move further.
January 21, 2025 at 9:34 am #16617299
Carlos Rojas
Hi Mario,
I edited the product hidden link and the scenarios are not added. After disabling the WPML plugins nothing changes. Could you add the scenarios in hidden link ?
