Last updated by Mihai Apetrei 7 months, 3 weeks ago.
Assigned support staff: Mihai Apetrei.
June 24, 2019 at 8:19 am #4075371
giacomoV-7
Tell us what you are trying to do? I set up the wpml but when I finished my site was a total mess. I am afraid I am not able to make it.
Is there any documentation that you are following? yes, the tutorial you sent me within my purchase
Is there a similar example that we can see? I wouln't know
What is the link to your site? hidden link
June 24, 2019 at 8:33 am #4075497
giacomoV-7
Please Help
June 24, 2019 at 11:02 am #4076737
Mihai Apetrei
Hi and thank you for contacting WPML Support!
I will be more happy to help you with this.
From what I can see, the theme that you are using is not part of our official WPML-compatible directory here (https://wpml.org/documentation/theme-compatibility/) but I would be more than happy to take a look and see if there's any way I can help with this.
1. First of all, can you please let me know what are the exact steps that you took and what happened? If you have any more screenshots or screen recordings, please share them with me. Also, can you please let me know what is exactly that you are trying to accomplish?
2. I have noticed that your website’s WP Memory Limit is 40MB. The WP memory limit needs to be increased as the minimum requirement for WPML is 128Mb WP Memory Limit: https://wpml.org/home/minimum-requirements/
❌ Very important: please make a backup of your site (files & database) before following any of the upcoming steps ❌
Please add this to your wp-config.php file to increase WP memory:
/* WP Memory Limit */
Paste it just before:
These settings can be limited directly by your hosting provider, so, if that’s the case, I recommend you to contact and ask them to modify them directly. If you can get even higher values It would be great.
Please make sure you have updated the values successfully, You can verify them from WPML >> Support page.
3. I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
- Please make a backup of the site files and database before providing us access.
- If you do not see the wp-admin/FTP fields this means your post & website login details will be made PUBLIC. DO NOT post your website details unless you see the required wp-admin/FTP fields. If you do not, please ask me to enable the private box.
The private box looks like this: hidden link
Kind regards,
Mihai Apetrei
The topic ‘[Closed] I need help because I'm not so confident with the configuration of WPML’ is closed to new replies.
