Problem: I created a custom snippet in PHP and I don't know how can I translate it.
Solution: https://wpml.org/forums/topic/i-need-help-translating-a-snip/#post-4290471
Related documentation:
Last updated by javierr-35 1 year, 6 months ago.
Assigned support staff: Mihai Apetrei.
July 26, 2019 at 11:00 am #4289259 | |
javierr-35 |
add_filter('woocommerce_thankyou_order_received_text', 'woo_change_order_received_text', 10, 2 ); i cant seem to translate that string |
July 26, 2019 at 3:34 pm #4290471 | |
Mihai Apetrei Supporter
Languages: English (English ) Timezone: Europe/Bucharest (GMT+02:00) |
Hi and thank you for contacting WPML Support! I will be happy to help you with this. Please use this instead of that part from the code that you have: $str . __(' <br><br><b>IMPORTANT: If you do not receive your availability response, check your "spam" or "spam" email or check that the email you have given us is correct. </b><br><br>Read carefully the instructions to make the payment of the deposit and information on how to get to the surf camp.', "my-custom-domain"); Here is some helpful documentation for that: After saving it, please see if you can now find it in WPML > String Translation. If you don't, you might need to scan the theme that's generating the strings and then go back to WPML > String Translation and see if the strings show up: Please let me know if this solved your issue or if you still need help. I will be waiting for your response. Just a note that I won't be working on the weekend so I will be able to get back to you at the beginning of next week. Kind regards, |
July 27, 2019 at 9:52 am #4293071 | |
javierr-35 |
hi thanks mihai, but im runnin in to the next issue each time i save it i will get this error in the front end this is the new code added add_filter('woocommerce_thankyou_order_received_text', 'woo_change_order_received_text', 10, 2 ); error code Warning: _() expects exactly 1 parameter, 2 given in /homepages/5/d358190389/htdocs/clickandbuilds/BLACKSTONESURFCAMP/wp-content/plugins/code-snippets/php/snippet-ops.php(361) : eval()'d code on line 3 |
July 29, 2019 at 1:11 pm #4300061 | |
Hi. I think the issue might be due to the fact that you are using just one underscore instead of two. I am attaching a screenshot - there we will need to have 2 underscores, one next to each other, instead of just one. Like this: __( Please let me know how that goes and if that solved the issue. Kind regards, |
July 29, 2019 at 2:46 pm #4301055 | |
javierr-35 |
My issue is resolved now. Thank you! |
