Last updated by Otto 2 years ago.
Assigned support staff: Otto.
November 27, 2019 at 2:12 pm #5029973
sandipS-3
I need urgent help from you guys. My site is not working properly at all
November 27, 2019 at 2:39 pm #5030107
sandipS-3
why I am getting this issue
November 27, 2019 at 3:40 pm #5030611
Otto
Hi there!
Our devs are checking the problem.
Meanwhile, it may help if we can take a look at the site.
If it is OK for you, I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue.
** IMPORTANT **
- If you do not see the wp-admin/FTP fields this means your post & website login details will be made PUBLIC. DO NOT post your website details unless you see the required wp-admin/FTP fields. If you do not, please ask me to enable the private box. The private box looks like this:
Kind regards,
Otto
November 27, 2019 at 4:58 pm #5031365
Otto
And don't worry. Apparently this should be fixed on our side. So, we won't log into your site for now.
Our devs will get it done and I will update you here. I think it should be ready tomorrow.
Please, apologize for the inconveniences.
I'll keep you posted.
Kind regards,
Otto
November 27, 2019 at 5:03 pm #5031385
sandipS-3
see few words are not translating even after doing translation from backend
November 27, 2019 at 5:08 pm #5031423
sandipS-3
another issue. different url
November 27, 2019 at 7:46 pm #5032083
Otto
The original problem of this ticket should be fixed now. Can you please check and confirm?
For the other issues, may I kindly ask you please to open a new ticket for each question? This way we will be able to help you better and also help other users with similar problems find solutions when searching the forum.
Thank you!
