Problem: The user was not able to update WPML plugins Solution: Go to Dashboard->Updates and click on the button to check updates. Then go to Plugins->Add New->Commercial(tab) and update WPML Multilingual CMS first, then update the other plugins.
Last updated by robv-11 8 months ago.
September 27, 2019 at 1:35 pm #4654517
robv-11
After updating WPML, I have the message that updates for
sitepress-multilingual-cms, wpml-string-translation and wpml-translation-management are needed.
I expected those to be updated automatically, as the website is registered, but that is not the case.
I downloaded the zip files, and tried to install them, but could not over write the old versions.
I am hesitating in removing the old versions by hand, and uploading the new versions....
September 27, 2019 at 2:14 pm #4654919
robv-11
Thanks for this, I did not know they were there!
But
I get this message: Download failed! Please refresh the page and try again.
September 27, 2019 at 2:17 pm #4654923
robv-11
