This topic contains 42 replies, has 3 voices.
Last updated by raymondL-6 1 year, 8 months ago.
October 9, 2019 at 1:19 am #4718511
raymondL-6
I am trying to: Import WooCommerce product translations in a second language using WP All Import.
Import setting:
Import file:
I expected to see:
Linked product translations
Instead, I got: not linked to existing default language products.
October 10, 2019 at 6:04 am #4727471
Bigul
This may be happening because of the older version of the WPML plugins. Please upgrade to the latest version(4.2.9) after a full site backup and make sure the issue is existing or not.
I hope you are following the exact steps described in the below documentation.
https://wpml.org/2018/10/import-multilingual-content-with-wpml-and-wp-all-import/
https://wpml.org/documentation/related-projects/wpml-all-import-plugin-website-import-with-wpml/#how-to-import-woocommerce-products
Also please refer to the detailed documentation from WP All import
- How to import WooCommerce products
- How to import WooCommerce Variable product
Bigul
October 11, 2019 at 1:18 am #4734533
raymondL-6
Hi, I can't update the plugin. How to fix it? thanks
October 11, 2019 at 12:47 pm #4738349
Bigul
Thank you for the updates. You are getting Update failed: undefined error because of the installer caches. Please try the following steps after a site backup
1) Go to Plugins>>Add New>>Commercial
2) Press the *Check for updates* button
3) Then try to upgrade the plugins from Commercial page
4) If the issue exists, go to https://wpml.org/account/sites/ look for your current key and erase it.
5) Create a new one for your site.
6) Go to Plugins>>Add New>>Commercial
7) Click on the *Unregister WPML from this site* button
8) Register WPML adding your new key
9) Then try to upgrade the plugins from Commercial page
Bigul
October 14, 2019 at 5:37 am #4746975
raymondL-6
Hi, I have successfully updated wpml plugin, Thx!
I try to import csv again, still not linked to existing default language products.
October 14, 2019 at 12:12 pm #4749671
Bigul
Thank you for the updates. I would like to access the admin area of your site for further checking. Please fill the private details fields after a full site backup.
Please check the following links for more details about our private information sharing policies.
Bigul
October 16, 2019 at 3:07 pm #4766873
Bigul
Thank you for the login information. One doubt. In All Import>>Manage Imports section only one import task is existing and it is for Chinese.
Have you deleted the rest of the import tasks because of the issue? Or is it a staging site for our testing?
Please check the attached image for more details and let me know your feedback.
Bigul
October 17, 2019 at 1:17 am #4769317
raymondL-6
Hi, the import file is for testing purpose. It can be deleted. If you want to test the import function, please use the csv file I provided, Thx
October 17, 2019 at 1:59 pm #4774501
Bigul
Thank you for the updates. I have tried to import the English CSV file. But it is creating the products in English without connecting with the Chinese products. Please check the attached images.
Therefore I would like to try another round of testing with it. Can I try after deactivating a few plugins of your staging site? Please let me know your feedback.
Bigul
October 18, 2019 at 12:44 am #4777627
raymondL-6
Can I try after deactivating a few plugins of your staging site? <---- ok thanks!!
October 18, 2019 at 11:23 am #4781343
Bigul
Thank you for your permission. I am continuing the testing on this. As a part of our escalation process, I have tried to reproduce the issue in a fresh installation. But it works on a fresh installation and only one product is added. Please check the following test site URL.
On your site when I run the Chinese Traditional Import file it is updating the already existing products. If I run the English Import file it is creating new Products. But the Jabra Products of Chinese Traditional language is already translated.
So you are expecting the existing English Translations will update if you run the English Import file, am I right?
Please check the attached images for more details and let me know your feedback.
Bigul
October 21, 2019 at 1:19 am #4790443
raymondL-6
We don't need to update the product info when we run the English Import file. For Jabra Products, it is possible that it is translated to English in my testing but did not rollback.
About your testing result in our site, do you mean that the Chinese Traditional Import file and English Import file are successfully run?
October 21, 2019 at 2:09 pm #4795131
Bigul
Thank you for the feedback. Please check the attached images. Now I am getting the following results.
a) When I import Chinese Traditional CSV files, it updates the already existing Jabra products in Chinese Traditional language
b) When I import English CSV files, it creates or updates the already existing Jabra products in English. But those English products are not related or linked to the existing Chinese Traditional Jabra products
But in a fresh installation, I am almost getting the expected results. Therefore checking about the issue with our developers now. We have a request. Please allow us to make a duplicator copy of your site using the Duplicator plugin(https://wordpress.org/plugins/duplicator/) for debugging the issue on my local server.
Bigul
October 28, 2019 at 4:05 am #4836099
raymondL-6
Please allow us to make a duplicator copy of your site using the Duplicator plugin(https://wordpress.org/plugins/duplicator/) for debugging the issue on my local server. <--- OK, Please install duplicator plugin on hidden link, Thanks!
October 28, 2019 at 3:31 pm #4841243
Bigul
Thank you for the permission. But I am not able to login to the site because of *Error: Invalid Password*. Have you changed the credentials? Please check.
Bigul
