Last updated by Bruno 2 years ago.
May 15, 2018 at 1:52 pm #2140652
jurgenR
We extented our page with Pods images. When I add an image in the main language Dutch the image is also copied to German which is fine but the image is not copied to English.
Why is this different?
The image which is copied to German contains the Dutch image. Is has the image ID of 2206 but the image in German should be 2208.
Can you please tell me why the image is only copied to German and how come the image in German has the Dutch data and not the German data. In de Media the image did get translated.
May 17, 2018 at 1:37 am #2165955
Bruno
Thank you for contacting us.
Has this happened with new posts as well or only with old posts?
I'm not sure if I understood that. For your screenshot, you have marked the "image" custom field to be "Translatable". In this case, you should add the secondary image ID manually. Using image ID manually, does the problem persist?
The topic ‘[Closed] Images from post copied to German with Dutch texts and not copied to English’ is closed to new replies.
