The client is trying to import variable products in multiple languages (Danish and German) using a Google Docs template exported as a CSV file. However, only the German variations are being imported as separate products, and none of the Danish variations are imported.
First, ensure that the column titles in your CSV file are correctly formatted for WPML. Incorrect column titles can prevent the correct import of multilingual content. After adjusting the column titles, follow these steps:
1. Import your products using the corrected CSV file.
2. Go to WPML > Export and Import to run the multi-language content process as described in our documentation here: WPML Export and Import.
If this solution does not resolve your issue or seems outdated, please check our related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. If the problem persists, do not hesitate to open a new support ticket for personalized assistance at WPML support forum.
Last updated by Long Nguyen 1 year, 10 months ago.
Assisted by: Long Nguyen.
June 12, 2024 at 9:04 am #15729856
ritaB-8
I'm trying to make a Google Docs template that I can use and fill out, then export as a CSV file, and import as new products. The products need to be variable, so that I can have different sizes, like small, medium, and large. They also need to be in multiple languages, Danish and German. I have been using this video, but I just use the WooCommerce native importer, instead of the plugin he is using. hidden link
No specific issue or error message mentioned.
How can I create a Google Docs template for importing variable products in multiple languages using WPML?
What steps should I follow to export the template as a CSV file and import it into WooCommerce?
How can I ensure that the products are correctly imported in both Danish and German?
June 12, 2024 at 10:59 am #15731055
ritaB-8
After having talked with the support chat, we still didn't find a solution. I hope we can figure this out as soon as possible.
Let me know if you need more information from me.
June 13, 2024 at 2:26 am #15733837
Long Nguyen
WPML Supporter since 02/2022
Languages: English (English ) Vietnamese (Vietnamese )
Hi Rita,
Thank you for contacting WPML support, I’m happy to help you with this issue.
After importing products, you will need to go to WPML > Export and Import to run the multi language content process. Refer to step 5 in the documentation
https://wpml.org/documentation/related-projects/wpml-export-and-import/#run-wpml-export-import
If it still doesn't work on your site, please share the import file that you are using. And I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. It would be better to have a testing site where the issue is replicated. Your next reply is set to private to share the info.
June 14, 2024 at 2:30 am #15738073
Long Nguyen
You can upload the import file to Google Drive or DropBox and share the URL here.
June 14, 2024 at 11:57 am #15739993
ritaB-8
Here is a link to download the import file, by WeTransfer: hidden link
June 17, 2024 at 1:43 am #15743131
Long Nguyen
I notice that the column titles _wpml_ in the import file isn't correct. I correct this and import products on your site and it works properly.
Here is the import file URL
and screen record of importing products
You will need to open the URL in a new tab to view the screen record.
June 17, 2024 at 7:17 am #15743519
ritaB-8
Great, now the language function with the products seems to be working. However there still seems to be a problem with the variation function.
Right now the two variations are importet as seperate products, instead of being the same product, but with the possibility to choose it in both small(Lille) and Large(Stor).
Is the columns "Attribute Name(pa_size)" and "Attribute Value (pa_size)" wrong?
June 17, 2024 at 8:10 am #15743812
Long Nguyen
You can follow the WooCommerce documentation to import the variable product and its variations https://woocommerce.com/document/product-csv-import-suite/product-csv-import-suite-importing-product-variations/
However, I see that it isn't related to the multilanguage import product issue. So if you see the main issue of this ticket is resolved, please mark it as Resolved.
