May 16, 2018 at 7:10 am #2150506
danielM-40
I am trying to import the product from my old website to new website. I export the products using Wp Export plugin from old website and when import into new website everything will be import properly expect WPML translation.
I used the below steps to import the products with translation:
Export Product from old site using WP All Export
Import the main language (en) product into new website everything imported properly.
When import the second language (nb) product is imported but not importerd the translation with main language. Please check my settings hidden link
Imported into:
English CSV file:
Norwegian CSV file:
May 17, 2018 at 4:42 pm #2179930
José Arcos
Hello, thank you for contactin WPML Support. I will do my best to help you.
I think that the problem is that you are not using the proper Unique Identifier, when importing the English product, select the value "WPML Translation ID", and then, when import Norwegian products, use that value also when defining the parent import as you mentioned in the screenshot.
Please, let me know if this solves the issue or you need further assistance.
Have a good day.
