Last updated by Bruno Kos 9 months, 1 week ago.
Assigned support staff: Bruno Kos.
August 26, 2019 at 10:28 am #4457643
reneU-2
Hello, Is there a way to enable Quick edit for translated products? I have an online store, with 7 different languages and need to edit each Title and Description - and I want to speed up the process.
August 26, 2019 at 10:40 am #4457723
Bruno Kos
Please see this answer:
https://wpml.org/forums/topic/quick-edit-is-disabled-for-product-translations-how-do-i-fix-this/#post-1348668
Bruno Kos
August 29, 2019 at 1:04 pm #4481199
reneU-2
So there is no way to use it?
Because I am trying to add Meta title and description to 100 products in 7 languages, and without quick edit it takes forever...
August 29, 2019 at 1:23 pm #4481351
Bruno Kos
I'm afraid there isn't solution, it is not possible to do this while WooCommerce multilingual is active. However if you temporarily disable WooCommerce multilingual, then quick edit will work on translations, but this is not something I have tested nor should be recommended.
But in case you can make a full site backup, you can try.
Bruno Kos
