The client is experiencing issues with WPML on their website where some words are not translated into Arabic, and some details are missing in the Arabic version of the property details section.
1. We recommended following the steps in the WPML documentation to find and translate untranslated strings. For more details, visit https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/
2. Ensure all steps are followed as described in the WP Residence theme's specific WPML guide at https://help.wpresidence.net/article/wpml-help/
3. We checked the site and found that the strings appear translated when accessing the site in incognito mode, indicating a cache issue. We advised the client to consult with the theme authors to resolve the cache issue caused by the theme.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If problems persist, please open a new support ticket.
This topic contains 16 replies, has 0 voices.
Last updated by masterP 10 months, 2 weeks ago.
Assisted by: Carlos Rojas.
April 2, 2025 at 10:02 am #16886242
masterP
I am trying to use WPML on my site hidden link to switch to the Arabic version.
When I switch to the Arabic version, some words do not appear. And some words are not translated
April 4, 2025 at 12:36 pm #16897464
Carlos Rojas
WPML Supporter since 03/2017
Thank you for contacting us
Please follow the steps described in this guide: https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/ to find and translate the untranslated strings.
It is also recommended to make sure you followed all the steps described in hidden link
Carlos
April 7, 2025 at 9:16 am #16903087
masterP
I made all the steps and the issue is not solved
April 7, 2025 at 10:37 am #16903625
Carlos Rojas
Please share the access credentials to the site in your next message that I have set private.
Confirm you created a full site backup that you can use to restore the site if necessary.
April 8, 2025 at 8:42 am #16907601
masterP
[REMOVED]
April 8, 2025 at 9:31 am #16908047
Carlos Rojas
Thank you for sharing the credentials.
I have visited the site and I can see all strings translated: hidden link
Can you share a URL where the issue can be seen?
April 8, 2025 at 9:59 am #16908229
masterP
you can see the issue in any page in property, when you visit the property page and switch to Arabic you can see some words in English, and I already translated the words in strings translated, also there are some words in Property Details not showing.
and now I'm checking the website I Found another issue, when I click on languages in menu open different page
April 8, 2025 at 10:11 am #16908265
Carlos Rojas
Please finish the Arabic translation of this template: hidden link
April 8, 2025 at 10:58 am #16908652
masterP
Hi Carlos,
Thank you for your help and quick response.
Where would you like me to translate to Arabic?
Can you share a screenshot with me?
April 8, 2025 at 11:03 am #16908688
Carlos Rojas
Hi, sure!
Attached you will find a screenshot indicating where you need to click to update the translation.
FireShot Capture 115 - Edit Template “Property Template V1” ‹ Master Plan Real Estate FZE _ - [dubaimasterplan.com].png
April 8, 2025 at 11:08 am #16908726
masterP
Done, but only the page title needs to translate
Please see the screenshot.
April 8, 2025 at 12:00 pm #16909154
Carlos Rojas
It seems there is a cache problem, because visiting the properties on incognito mode shows all strings translated: hidden link
April 8, 2025 at 12:33 pm #16909319
masterP
Thank you
There are some words that are not translated into Arabic
I translated them before
I put highlight on them in the screenshot
April 8, 2025 at 12:38 pm #16909339
masterP
Another problem, there are missing details in the property details section.
You can check the difference between the number of details in the ENG version and the AR version.
In the English version, there are 7 details, while in the Arabic version, there are only 3 details.
April 8, 2025 at 1:13 pm #16909578
Carlos Rojas
This seems to be a cache issue, check the attached image.
FireShot Capture 116 - بن غاطي سكاي هول في الخليج التجاري، دبي - Master Plan Real Estate F_ - [dubaimasterplan.com].png
