Last updated by Shekhar Bhandari 7 months, 1 week ago.
December 7, 2024 at 6:34 pm #16488745
kisa
I am encountering an issue with the translation validation process on my website.
After completing and validating translations, the system frequently does not register them as validated and keep the orange color. I often have to repeat the process two or three times before the translations are marked as complete with the green color.
Could you please assist me in resolving the issue with translation validation not saving properly?
December 8, 2024 at 9:59 am #16489472
Christopher Amirian
WPML Supporter since 07/2020
Welcome to WPML support. I will try to answer the question before the ticket is assigned to one of my colleagues.
It is very hard to detect what might be the problem cause but checking the debug information, I have a few ideas that needs to be checked to see if that is the cause of the problem.
The first one is the PHP memory limit that your WordPress installation uses, which is below the standard WPML needs.
The minimum requirement is 128M but I suggest that you increase it to 512M: https://wpml.org/home/minimum-requirements/
You can add this by adding the code below to "wp-config.php" file of your WordPress installation root folder:
/** Memory Limit */
define('WP_MEMORY_LIMIT', '512M');
define( 'WP_MAX_MEMORY_LIMIT', '512M' );
Please add the code above the line below:
The other point is a possibility of a plug-in conflict that you can check following the steps below:
- Switch to the default theme such as "TwentyTwenty" by going to "WordPress Dashboard > Appearance > themes".
- Go to "WordPress Dashboard > Plugins" and deactivate all plugins except WPML and its add-ons.
- Check if you can still recreate the issue.
- If not, re-activate your plugins one by one and check the issue each time to find out the plugin that causes the problem.
December 16, 2024 at 1:49 pm #16517628
kisa
Hello and thank you for your reply
I upgraded the memory limit.
I also noticed another problem: I make sure to translate my products entirely, and now sometimes it regressed and when I go back when or two sentences are still in orange, even though when I saved it it was 100% translated... It worries me...
And how can I make a staging website as to not break my current website?
December 17, 2024 at 5:29 am #16519722
Shekhar Bhandari
WPML Supporter since 03/2015
Hello there,
I will be helping you further on this issue.
Can you provide me few pages examples where I can see the issue?
Further, can you elaborate on this?
To further, help you on this issue, I would need to check your site settings once, for this I would need temporary access (wp-admin and ftp) to your site.
Note:
Look forward to your reply.
The topic ‘[Closed] Issue with Translation Validation Not Saving Properly’ is closed to new replies.
