Last updated by Jordi Romeu 2 years, 11 months ago.
Assigned support staff: Bobby.
August 29, 2017 at 2:54 pm #1353504
Jordi Romeu
I have WordPress and WPML installed in a server I have no full control. Have only acces to ftp and mysql, but no control panel or cpanel.
I had WPML installed with 2 languages (catalan and spanish). I want to install a third language (french).
I can access correctly to the catalan and spanish versions:
hidden link - catalan
hidden link - spanish
But I can't access french version:
I've translated the home page but can't access its url.
In WPML -> Languages -> Language URL format there's the red message "It looks like languages per directories will not function.".
Clicking on details it says:
When WPML accesses hidden link it gets:
cURL error 60: Peer certificate cannot be authenticated with known CA certificates
But when I access that url from my browser it does not show this error. I see this on code source:
<!--hidden link;
Maybe there's some kind of problem with the SSL certificate and WPML to check the directory working ok?
Thansk for your support.
August 29, 2017 at 4:45 pm #1353627
Bobby
Thank you for contacting WPML Support,
When i visit your site i was able to see it as expected on the /fr/ directory as well as the other ones.
The specific warning a lot of times can be a false negative. If you are able to see the home page with no errors 404 , or a blank page then it is most likely a false negative warning.
August 29, 2017 at 8:49 pm #1353798
Jordi Romeu
Hi Bobby,
Woow... Yes! I can see it when I'm not logged in. But when I'm logged in, when I access hidden link, it redirects me to hidden link.
Do you know whats happening?
Jordi
August 30, 2017 at 6:52 am #1353947
Bobby
Hi Jordi,
Please make sure that you have cleared your Cache.
If issue persists please sent me a screenshot of your settings for the Language URL format within the Languages page.
August 30, 2017 at 7:25 am #1353969
Jordi Romeu
I have cleared cache from WPML > Support > Troubleshooting.
But it continues not working.
I attach a screenshot of settings. I have hidden the language french to visitors and activated in my profile to see it.
But it's not working.
I see this message too:
WordPress cannot automatically download translations for the following languages:
French (current locale: fr_FR) - suggested locale(s): fr_BE, fr_FR, fr_CA
Spanish (current locale: es_ES) - suggested locale(s): es_MX, es_AR, es_VE, es_CO, es_GT, es_PE, es_CL, es_ES
To fix, open "Edit Languages" and set the "default locale" values as shown above.
But in "Edit languages" all is ok. Capture attached.
August 30, 2017 at 7:55 am #1353998
Bobby
**Before we proceed I recommend to please take FULL BACKUP of your database and your website.**
I often use the Duplicator plugin for this purpose See: http://wordpress.org/plugins/duplicator/
I would like to request temporary access (wp-admin and FTP) to your site to fix the issue.
Thank you,
Bobby
August 30, 2017 at 9:18 am #1354083
Bobby
Hi There,
I believe you need to clear your browser's cache.
Also try accesing your site from a different browser.
Im able to view the languages as expected when logged in.
Also regarding the warning in the top its related to your default locales, its not an error. Just update your WP to the latest version and let me know if it goes away if not i can just erase it.
August 31, 2017 at 9:04 am #1354961
Jordi Romeu
It was a cache problem. I erased my cache and now is working ok.
