This topic contains 18 replies, has 2 voices.
Last updated by Bobby 1 year, 12 months ago.
Assigned support staff: Bobby.
July 2, 2018 at 11:42 am #2453369
davidG-36
I have 3-language website and has a problem with the Language URL format. I use Different languages in directories and it shows the message 'It looks like languages per directories will not function.'
I don't know what is the reason, because:
1. WordPress is NOT installed in a directory, installed in root.
2. URL rewriting is enabled on my inmotionhosting.com web by default.
3. The web server can write to the .htaccess file.
Also, fopen is enabled on my server and .htaccess file contain the following:
# BEGIN WordPress
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /index.php [L]
</IfModule>
# END WordPress
But anyway, I have the error you can check on the attached image.
I'm using:
WPML Multilingual CMS - Version 3.9.3
WPML String Translation - Version 2.7.3
WPML Media - Version 2.2.3
WPML Translation Management - Version 2.5.2
website url is hidden link
July 3, 2018 at 4:28 pm #2458650
davidG-36
Hello, Is anyone here?!
July 4, 2018 at 12:12 am #2459851
Bobby
When i visit your site i currently can view the front end as expected for both default language and secondary language.
This is a common false negative notice, and the best way to verify this is by visiting the front end.
if the front end is displaying as expected , then this is verified as false negative and you can continue using the URL Structure without problems
if you are seeing an error 500, blank page or error 503 in the front end and its resolved by changing the URL Structure then we will need to further inspect the issue.
July 4, 2018 at 7:16 am #2460426
davidG-36
Hello Bobby,
Thanks for your reply.
The problem is, that I can't create/edit the cars in the back end BUT ONLY in English and Russian languages. I get the message: "This page isn’t working. carsandrooms.ge is currently unable to handle this request. HTTP ERROR 500"
But in third, Hebrew language, which is hide right now, I can create/edit the cars. Appears it or not, it doesn't matter.
I use Traveler theme version 2.1 and theme's official support said, that it caused by WPML plugin.
For example, they said it here hidden link
And here:hidden link
Anyway, it's quite strange, that I can't create and edit the car pages from primary and secondary languages and can do it fro third language, is not it?
Could you please further inspect the issue and try to help me?
July 4, 2018 at 9:16 pm #2465143
Bobby
I do not believe this is related to your language URL structure being set to "languages per directories" this is a false negative notice you are getting , which we have seen happen in many different servers.
to further verify , regarding the error 500 you are experiencing when you are trying to edit and create cars , is it resolved when you switch your language url structure to "...added as permalinks.." instead of directories ?
also what are your results in a minimal enviroment as this could be relate to some compatibility
please test this:
-Back up your site first
-Deactivate all non WPML related plugins
-Switch for a moment to a WordPress default theme like Twenty Fourteen.
-If the issue is gone, activate one by one to see with wich one there is an interaction issue
Let me know your results
July 5, 2018 at 5:22 pm #2468559
davidG-36
I think you meant "...added as parameter" instead of "...added as permalinks".
Yes, I tried it. Same result.
About the minimal environment, I use InmotionHosting's VPS package, so don't think, I have a compatibility problems. But if you tell what kind of information you need, I will provide you with it.
About the test: I found, that car edit/create errors has gone after I deactivated the OptionTree plugin which is necessary for the traveler theme.
July 5, 2018 at 9:03 pm #2469340
Bobby
Therefore you should be able to set your Language URL Format as "Different languages in directories" and disregard the notice as mentioned in my previous reply.
https://wpml.org/forums/topic/it-looks-like-languages-per-directories-will-not-function-58/#post-2459851
Regarding the error this seems to be related to a compatibility between WPML and OptionTree plugin for the traveler theme.
if possible please verify you are using the latest versions of your theme and its plugins.
also let me know if you can find your theme in our list of comaptible themes
https://wpml.org/documentation/theme-compatibility/
we usually recommend contacting your theme provider first regarding this compatibility and afterwards we can move forward with the compatibility process , do keep in mind that we cannot do all the work from our side and if there is indeed a compatibility issue we will need the author to work with us as well.
July 6, 2018 at 2:31 pm #2471117
davidG-36
Thanks for your reply. Yes, I am using the last version of Traveler theme and its plugins.
About the compatibility, I found traveler theme in your list, but it was Tested on: 26/Jan/2016 and the status is "Compatible with WPML, Has known issues".
Of course, Traveler team knows and works with this problem, but we have no result yet.
July 7, 2018 at 6:19 pm #2472866
Bobby
If possible i would like to take a closer look
**Before we proceed I recommend to please take FULL BACKUP of your database and your website.**
I often use the Duplicator plugin for this purpose See: http://wordpress.org/plugins/duplicator/
I would like to request temporary access (wp-admin and FTP) to your site
Thank you,
Bobby
July 9, 2018 at 8:47 am #2475537
davidG-36
Ok, I will prepare the test version of website and provide you with all credentials.
I need one day for this.
July 9, 2018 at 4:37 pm #2477203
Bobby
Private message re enabled
update here once ready and i will be notified.
July 13, 2018 at 10:51 am #2492010
davidG-36
Hello. Updated. Please, let me know if you need more info/details.
July 13, 2018 at 5:56 pm #2492618
Bobby
Thank you for the access details !
i can see that the theme support has updated you and mentioned that this issue should be fixed in their next release , correct ?
July 13, 2018 at 6:26 pm #2492663
davidG-36
Yes, but the problem is, that they are saying this more then 3 weeks already to another users. For example, this man is waiting from June 21 and still has no solution. And he is not alone. hidden link
First they said it was a problem of .htaccess file, then the unsecure connection was the next reason, then they said, it caused by WPML... I think they still don't know what is the reason. That's why they can't declare the next release day.
And another problem is, that every their update has the new bugs and they always say "this issue should be fixed in their next release" and I'm waiting again and again and again... and so on endless and this continues about two years already.
July 13, 2018 at 8:54 pm #2492792
Bobby
The following errors are the reason this happens
Fatal error: Uncaught Error: Class 'ST_Flight_Location_Models' not found in /Applications/MAMP/htdocs/c/wp-content/themes/traveler/inc/travel-helper.php on line 4415
( ! ) Error: Class 'ST_Flight_Location_Models' not found in /Applications/MAMP/htdocs/c/wp-content/themes/traveler/inc/travel-helper.php on line 4415
This is definitely an issue with the theme's code as they have mentioned this is the reason they are working on it to include a fix for the next release.
from our side I can escalate this to our compatibility team and our compatibility team will try to contact them regarding this issue and test this issue further.
if this is verified by our team as well that this is not an issue with WPML then unfortunately we will not be able to provide a fix for their code , once there are news we will update you here.
