Last updated by Bigul 1 year, 1 month ago.
April 30, 2019 at 11:29 am #3710667
snaethorG
I am trying to: set "Language URL format" as "Different languages in directories"
I expected to see:
Instead, I got:
It looks like languages per directories will not function. Details
This can be a result of either:
WordPress is installed in a directory (not root) and you're using default links.
URL rewriting is not enabled in your web server.
The web server cannot write to the .htaccess file
How to fix
When WPML accesses hidden link it gets:
Too many redirects
The expected value is:
<!--hidden link;
April 30, 2019 at 5:42 pm #3713953
Bigul
Welcome to the WPML support forum. I will do my best to help you to resolve these issues.
Please make sure URL rewriting is not enabled in your web server. Check the following documentation for more details.
https://wpml.org/documentation/getting-started-guide/language-setup/cannot-activate-language-directories/#make-sure-that-wordpress-enables-url-rewriting
Sometimes we will get this as false alarms. So please create a test post and translate it to secondary language and make sure you are getting the expected result in the frontend.
Bigul
The topic ‘[Closed] It looks like languages per directories will not function.’ is closed to new replies.
