Last updated by Rajeeb Banstola 10 months ago.
Assigned support staff: Rajeeb Banstola.
August 2, 2019 at 1:55 am #4325643
danielB-38
It looks like languages per directories will not function. Details
This can be a result of either:
WordPress is installed in a directory (not root) and you're using default links.
URL rewriting is not enabled in your web server.
The web server cannot write to the .htaccess file
How to fix
When WPML accesses hidden link it gets:
HTTP code: 403 (Forbidden)
The expected value is:
<!--hidden link;
August 2, 2019 at 4:12 am #4326699
Rajeeb Banstola
Thank you for contacting WPML!
Please follow the below instructions to debug the issue:
https://wpml.org/documentation/getting-started-guide/language-setup/cannot-activate-language-directories/
Also, make sure your server is set correctly:
https://wpml.org/faq/server-setting-for-languages-in-directories/
Let me know if you have any questions.
