Last updated by Bigul 5 months, 1 week ago.
September 16, 2019 at 7:11 pm #4583597
clarissaK
any Url Format for other languages not working in the website
September 17, 2019 at 9:21 am #4586977
Bigul
Welcome to the WPML support forum. I will do my best to help you to resolve these issues.
Most of the case it will be a false alarm. So please try the following steps and check the issue is existing or not.
1) Visit Settings>>Permalinks
2) Choose *Post name* option and save the settings
3) Visit WPML>>Languages>>Language URL format
4) Choose *Different languages in directories* and update settings
5) Visit Settings>>Permalinks and resave the settings
If the issue exists, please visit the following documentation and make sure you have the correct settings.
https://wpml.org/faq/server-setting-for-languages-in-directories/
https://wpml.org/documentation/getting-started-guide/language-setup/cannot-activate-language-directories/
Bigul
September 17, 2019 at 10:41 am #4587759
clarissaK
Hello..
Can you please check it?
when I switch in the language , I found error 404
clarissaimmigration.com
September 17, 2019 at 10:49 am #4587777
clarissaK
Actually I am not sure that, is this conversion showing publicly ?
Hello..
Let me know if you need wp-admin access ? I will give you update
September 17, 2019 at 5:55 pm #4590587
Bigul
Thank you for the updates. Please share with me the WordPress debug.log (not WPML debug information) for tracking the issue.
Please check this page for instructions https://wpml.org/documentation/support/debugging-wpml/
To enable it, open your wp-config.php file and look for define(‘WP_DEBUG’, false);. Change it to:
// Enable WP_DEBUG mode
define( 'WP_DEBUG', true );
// Use dev versions of core JS and CSS files (only needed if you are modifying these core files)
define( 'SCRIPT_DEBUG', true );
In this case, the errors will be saved to a debug.log log file inside the */wp-content/* directory. Please do the steps to reproduce the bug(when I switch in the language, I found error 404*) and check you are getting any errors or warning related to WPML in the log file.
If you can paste your debug.log to http://pastebin.com/index.php and provide me that link it would be great! (This is the cleanest way because sometimes the logs are long and create a complete mess of discussion).
Bigul
The topic ‘[Closed] It looks like languages per directories will not function’ is closed to new replies.
