Last updated by ariadnaM-3 7 months, 4 weeks ago.
Assigned support staff: Marcos Vinicios Barreto.
September 26, 2019 at 10:49 am #4645819
ariadnaM-3
I am trying to: configure WPML to use different directories for the different languages of my website.
I expected to see: When WPML accesses hidden link it gets:
HTTP code: 502 (Bad Gateway)
The expected value is:
<!--hidden link;
Instead, I got: a blank page
September 26, 2019 at 3:11 pm #4648255
Timezone: America/Bahia (GMT-03:00)
Thank you for contacting WPML Support. Before a more detailed look, please, make sure the following:
0 - Make sure you reviewed the instructions at: https://wpml.org/faq/server-setting-for-languages-in-directories/
1 - Your server supports mod_rewrite and you are able to use any other pretty permalinks other than the default one from your WordPress Dashboard > Settings > Permalinks settings.
See: https://wordpress.org/support/article/using-permalinks/
2 - Your website is not hosted in a subfolder inside your host public directory.
3 - Your .htaccess has the proper permissions so WPML can writing new rule for it.
See: https://wordpress.org/support/article/changing-file-permissions/#htaccess-permissions
Please, let me know if it works for you, have a nice day.
September 29, 2019 at 10:59 am #4660423
ariadnaM-3
Hello, thanks for your assistance, I've reviewed the three points and I think that I have them all good, but the problem still persists
September 30, 2019 at 5:21 pm #4666833
Thank you for the updates. I would like to request temporary access (wp-admin and FTP) to your site to take better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
Please, let me know if you need any additional details. Have a nice day.
October 1, 2019 at 5:22 pm #4674283
Thank you for the updates. Unfortunately the proivide details don't seem to be working, for example the wp-admin url of your website shows a '404 not found error' do you use any plugin to rename the WordPress Dashboard login url? Which is the exact url to reach your WordPress Dashboard? Also, the provided FTP details are not working, can you please review and test it? Thank you for your collaboration and patience, have a nice day.
October 2, 2019 at 7:19 pm #4682849
Thank you for the provided details. I took a detailed look in this issue and it seems to be a false positive, for example the call for hidden link is returning <!--hidden link; properly. See: https://wpml.org/documentation/getting-started-guide/language-setup/cannot-activate-language-directories/#how-wpml-determines-if-it-can-enable-languages-in-directories. Also I created a test page and add a translation for it, it also works as expected at:
English: hidden link
Spanish: hidden link
In your particular case your host seems to be blocking the fopen calls for the url validation and it seems to be the cause of the false positive warning messages. Please, ask them if fopen calls is enabled on your server or completely ignore the warning messages as we have the confirmation it works from my test page above.
Reference: hidden link
Note: I temporary unchecked the option to hide the spanish language in your WordPress Dashboard > WPML > Languages > Hide languages settings in order to confirm the languages in directories feature is working properly in your website.
Hope it brings a bit of clarifications for your questions, have a nice day.
October 2, 2019 at 7:46 pm #4682989
ariadnaM-3
