Last updated by olegV 1 year, 7 months ago.
October 15, 2018 at 5:35 pm #2818460
olegV
I am trying to: display the button for "Related Posts" in English and Russian on the respective language versions of the site. It's a JetPack module which does not behave like other plugins where I can choose Language Picker. I can rename the button to include both languages ("Related Posts/Похожие записи"), but that's less than ideal solution.
I expected to see: "Похожие записи" where "Related Posts" is displayed.
Instead, I got: English version on both languages
October 16, 2018 at 8:42 am #2820132
Riffaz
Hi Oleg,
Have you translated these string in WPML > String Translation : hidden link ?
Try to scan the string as explained here https://wpml.org/documentation/getting-started-guide/theme-localization/#scanning-plugins-for-texts and search then search that string in WPML > String Translation
If non-of these work for you please add this code to the very bottom of Appearance > Editor > functions.php
add_filter( 'gettext', 'wpml_jetpack_relatedpost_title_text', 20, 3 );
function wpml_jetpack_relatedpost_title_text( $translated_text, $text, $domain ) {
  if ( !is_admin() ) {
	if(ICL_LANGUAGE_CODE == 'ru'){
      switch ( $translated_text ) {
          case 'Related Posts' :
              $translated_text = __( 'What you prefer', 'jetpack' );
              break;
  return $translated_text;
Replace "What you prefer" with the text you want.
Let me know which one works for you please.
Riffaz.
October 16, 2018 at 10:14 am #2820519
Riffaz
Hi Oleg,
We found a small correction for this.
The right way to do this is adding the following xml code to WPML > Settings and click on the tab "custom XML configuration" :
<wpml-config>
  <admin-texts>
    <key name="jetpack_relatedposts">
      <key name="headline"/>
    </key>
  </admin-texts>
</wpml-config>
Refer : https://wpml.org/documentation/support/language-configuration-files/#using-wpml-language-configuration-file-with-child-themes
October 26, 2018 at 7:31 pm #2854142
olegV
Hi Riffaz!
Here is what I've done...
Custom XML configuration: I followed your second set of instructions to update "custom XML configuration". Unfortunately, it did not cause the desired effect on my posts.
String Translations: I've checked String Translations>Jetpack domain>Related Posts. I found several of them, but for all of them the translation was complete with correct "Похожие записи". Nevertheless, I updated each of them and forced to use my translation. It did not work...
Then I searched for "related posts" in String translation without limiting to "Jetpack" as the domain. And found this
Domain: admin_texts_jetpack_relatedposts Name: [jetpack_relatedposts]headline
this one was not translated. After providing translation, it worked.
Thank you!
Oleg
