This topic contains 23 replies, has 4 voices.
Last updated by blackbookdesign 1 year, 9 months ago.
Assigned support staff: Sumit.
August 5, 2018 at 7:14 am #2613433
jamieH-5
I have translated my site in four languages French, Chinese, Portuguese and Spanish. I want to keep my admin in English but I am not able to figure it out.
English is my default language. And Set admin language as editing language is unchecked.
I have checked so many solutions but none of them is working including renaming languages file in content/languages. Please provide me the working solution.
August 6, 2018 at 5:30 am #2614535
Shekhar Bhandari
Hello there,
Could you please go to Users->your Profile ->Language and set it to English.
Let me know if this helps.
August 6, 2018 at 7:02 am #2614643
jamieH-5
Yes, it is already set to English but still seeing admin translations.
August 6, 2018 at 10:26 am #2615398
Shekhar Bhandari
Hello there,
This seems unusual, to further debug this issue, I need to request temporary access (wp-admin and FTP) to your site in order to be of better help. You will find the needed fields for this below the comment area when you log in to leave your next reply. hidden link
These info is private, and available to you and supporters only. Read more about this: https://wpml.org/purchase/support-policy/privacy-and-security-when-providing-debug-information-for-support/
Note that:
#1
Backup (both files and database) your site before giving us your credentials. You can use a plugin for this if you like. I often use the Duplicator plugin for this purpose.
See: http://wordpress.org/plugins/duplicator/
Duplicator instruction
It would be better if you give me the test site rather than the live site.
#3
If the issues needs some changes in the plugins updates/disabling we will install a plugin called “duplicator” and replicate the site in our local server for testing.
Look forward to your reply.
August 8, 2018 at 4:37 am #2622733
Shekhar Bhandari
Hello there,
With the login details provided, I can see the whole dashboard in the English language so could you please check the issue once again?
August 8, 2018 at 9:03 am #2623514
jamieH-5
No, it is not. Did you even try changing the admin language?
August 8, 2018 at 12:45 pm #2624647
Shekhar Bhandari
Hello there,
Yes, I am able to replicate the issue now, it seems unusual as on my test site this feature is working without any issue, To further debug this issue, could you please provide me a backup of your wp-content (without uploads) as well as database backup so I can replicate your site on my localhost and perform further debugging.
You can zip these files and upload to google drive later to share it with me.
August 9, 2018 at 12:07 pm #2628652
Shekhar Bhandari
Hello there,
The database backup file you provided seems to be missing tables, could you please create a new database backup and send it to me.
Further, your site is also not working for me with the following message" This site can’t be reached" could you please check this?
August 9, 2018 at 5:47 pm #2630330
jamieH-5
I have updated the previous private reply. The new database is added please check it.
August 10, 2018 at 3:33 pm #2634492
Shekhar Bhandari
Hello there,
I tested this on my localhost and noticed that when deactivating Content Aware Sidebars plugin the issue is not happening, so could you please deactivate the plugin and let me know if this helps?
August 10, 2018 at 7:20 pm #2635259
jamieH-5
I disabled that plugin and the issue is still there.
August 13, 2018 at 11:00 am #2639526
jamieH-5
Can you guys give me a solution it's been more than a week?
August 13, 2018 at 11:40 am #2639633
Shekhar Bhandari
Hello there,
I replicated your site on my localhost and while using just WPML plugins (as well as when deactivating the plugin I mentioned earlier) the languages are working perfectly for me. It seems like some plugin/themes are also creating conflicts on your site.
So, is it possible for you to create a staging site so I can test this issue there? Could you please disable all non-related WPML plugins, switch to one of default themes, the problem persists or not?
NOTE:
+ Make a backup (both files and database) for your site before updating/proceeding anything (Always a good practice!).
August 15, 2018 at 5:33 pm #2647308
jamieH-5
Username = admin
Pass=jamie1234
Then Use the admin credentials I provided you to access the admin panel.
Please provide me the solution ASAP. It is affecting my sales.
August 16, 2018 at 10:42 am #2649313
Shekhar Bhandari
Hello there,
While trying to debug the issue using deactivate/activate the plugins, currently I am receiving the below errors so could you please check it once?
500 - Internal Server Error
 This is a temporary server error.
Please try to reload the webpage later.
