Problem: language switcher shows even if there are no translations.
Solution: setting post and pages as "Translatable - only show translated items". The option can be found at: - WPML -> Translation Option if you have the Multilingual Blog licence or - WPML -> Translation Management -> Multilingual content setup if you have the Multilingual CMS licence
Relevant Documentation: https://wpml.org/documentation/translating-your-contents/displaying-untranslated-content-on-pages-in-secondary-languages/
Last updated by Ioannis 2 years ago.
May 18, 2018 at 10:36 am #2188797
Ioannis
In Settings I have selected Skip language" when a post is untranslated.
The language selector works properly in some cases (in pages, blog page or blog archive), but it shows all languages in single posts, although none of these posts is translated in other languages.
1. hidden link , only the English flag shows because there are no translations. The language switcher functions properly.
2. Click on any post and then you will see all 3 flags, although the posts are not translated. The language switcher does NOT function properly.
Can you please help?
Yannis
May 18, 2018 at 3:02 pm #2189967
Laura
May I ask you to check your Post Types Translation preferences? They should be set on "Translatable - only show translated items".
You can find them in
or
Let me know if this helps you or if you need further assistance.
May 23, 2018 at 5:38 am #2212743
Ioannis
It was a setting in the Translation Management. In Post Type Translation, Posts were set to was set to "use translation if available". I changed it to "only show translated" and the issue was solved.
