Related documentation:
This topic contains 7 replies, has 3 voices.
Last updated by Nikita Nanos 3 years, 3 months ago.
November 9, 2017 at 3:10 pm #1426172 | |
Nikita Nanos |
Hi, The language toggle on our home page doesn't work. You can see the option to switch to French but you cannot actually click the link/button. This feature works on every page other than the home page. hidden link Thank you. |
November 9, 2017 at 6:22 pm #1426428 | |
Andrés Supporter
Languages: English (English ) Spanish (Español ) French (Français ) Timezone: Europe/Paris (GMT+01:00) |
Hello Nikita, Welcome to WPML support forum. While one of my teammates takes care of your case, please go to: If this is the case, but they are greyed and you can't modify them, please double check your database. If it was not the case and while another supporter takes personal charge of your situation, could you please provide a screenshot of the previous settings? Let us know if it helps. |
November 9, 2017 at 8:28 pm #1426536 | |
Nikita Nanos |
Hi, How would I access my data base? Yes, they are filled out and not modifiable. Just unsure why its only an issue on one page, while it works for all of the others. Thanks. |
November 10, 2017 at 5:04 pm #1427343 | |
Bruno |
Hi, This may be some cache issue with your server or the way it is configured. Please open the wp-config.php file at the root of your site and look for this line: /* That's all, stop editing! Happy blogging. */ Above this line, add these two lines: define('WP_HOME', '<em><u>hidden link</u></em>'); define('WP_SITEURL', '<em><u>hidden link</u></em>'); This will look like this: define('WP_HOME', '<em><u>hidden link</u></em>'); define('WP_SITEURL', '<em><u>hidden link</u></em>'); /* That's all, stop editing! Happy blogging. */ After following the steps above, save the changes and upload the wp-config.php file again. Please, let me know if after following these steps, the problem persists. Thank you. |
November 10, 2017 at 8:57 pm #1427555 | |
Nikita Nanos |
Hi, I did do this, I'm not 100% sure if the file was edited correctly. When I open it in notepad it displays the text a bit differently (no line #s). As far as I can tell I did it properly. I re-uploaded the updated file, cleared the browser cache and it still doesn't work. Any ideas? Thanks. |
November 10, 2017 at 11:18 pm #1427617 | |
Bruno |
Hi, Thank you. I'll need to request temporary access (wp-admin and FTP) to your site - preferably to a test site where the problem has been replicated if possible - in order to be of better help. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it. *** Note: Please make a full backup of your site. Privacy and Security when Providing Debug Information for Support: https://wpml.org/purchase/support-policy/privacy-and-security-when-providing-debug-information-for-support/ Thank you. |
November 13, 2017 at 7:06 pm #1429372 | |
Bruno |
Hi, Thank you. Inside the wp-config.php file, I made the changes I posted earlier and it looks like the language selector is working correctly now. Please, could you check if the language selector is working properly? Thank you. |
November 13, 2017 at 7:28 pm #1429398 | |
Nikita Nanos |
Hi, It works! Thank you for your help! Thanks. |
