Last updated by Otto 1 year, 5 months ago.
Assigned support staff: Otto.
September 19, 2018 at 8:50 am
andreasH-21
We have activated the message which is displayed to the customer, if he has products in the basket and is changing language, that if he really want to change the language, that the basket is automatically deleted. This message is normally shown in a lightbox.
But on new server it is show "transparent" with no lightbox, no background etc. It is nearby unreadable.
I found out, if I am logged in as admin, the lightbox is shown correct as usual.
Can you help?
Regards, Andreas
September 19, 2018 at 8:51 am #2747862
andreasH-21
Remark:
we can give you access to our new testserver if necessary in about 2 days.
September 19, 2018 at 11:02 am #2748471
Otto
Hello Andreas,
First, check this setting:
- Go to WPML > Languages > Language filtering for AJAX operations
- Check the following option
x Store a language cookie to support language filtering for AJAX
If the issue persists, clear the cache (site and server side)
Finally, if it is possible for you, do this test:
***Backup your site and DB before proceeding***
-Deactivate all the plugins but WPML and its addons, keep also WooCommerce and WooCommerce Multilingual
-Switch to a default WP theme (Twenty Sixteen for example)
-If the issue is gone, reactivate one at a time to see with which one is the conflict
Kind regards,
Otto
September 27, 2018 at 12:29 pm #2770446
andreasH-21
yes it was one plugin: CLEARFY.
And exactly this setting:
Performance -> Performance -> Disable Dashicons ON.
If you switch it off, everything works fine again.
Regards, Andreas
September 27, 2018 at 1:00 pm #2770605
Otto
Is this a suitable solution for you? Do you need anything else from our side?
Kind regards,
Otto
