You are developing a site using WPML's auto-translate feature and have encountered an issue where links within content translated using the Advanced Custom Fields (ACF) remain in the original language and point to the main language pages.
To resolve this issue, you need to modify your template code to ensure that links are correctly translated and point to the appropriate language versions. Here is a step-by-step guide:
  1. Ensure that your ACF link field is set to 'Translate' to allow for the translation of the link URL and text.
  2. Modify your template code to use the
    wpml_permalink
    filter for translating the URL, and the
    wpml_translate_string
    filter for translating the link title. Here is an example of how you can implement this:
    if ($link_url && $link_title) {<br />    $translated_link_url = apply_filters('wpml_permalink', $link_url);<br />    $translated_link_title = apply_filters('wpml_translate_string', $link_title, 'acf', 'link_title_' . $colourBox['link']['title']);<br />    echo '<a href="' . $translated_link_url . '">' . $translated_link_title . '</a>';<br />}
  3. Adjust the return value of the link field to 'Link URL' to ensure the correct data type is used for URLs.
Please note that this solution might be outdated or not applicable to your specific case. If this solution does not resolve your issue, we highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket.
This topic contains 16 replies, has 0 voices.
Last updated by Andreas W. 1 year, 1 month ago.
February 6, 2025 at 3:38 pm #16676286
vitaliiO
I am developing a site and using WPML's auto translate feature. I created an empty page with two links to other pages that have translated versions. I used the advanced editor to translate automatically.
The content is translated, but the links remain in the original language and continue to point to the main language.
For example, in the content, there is a link to the page "hidden link", and we have a French version of this page: "hidden link". However, the translation in the advanced editor kept the original version ("hidden link") instead of changing the link to "hidden link". You can see it on screenshot.
February 6, 2025 at 4:12 pm #16676446
WPML can handle internal links for default WordPress content and some default WordPress Blocks or some widgets of popular page builders.
Such internal links will usually not appear on the translation editor but we are currently having known issues with translating internal links inside buttons, calls to actions, and other similar blocks. Our developers are working on a solution for these issues.
The Color Box Link, seems to be a custom Block or Page Builder Widget. May I ask which plugin is responsible for this element?
For now:
If a link is not being handled as an internal link which is why it is appearing on the WPML Translation Editor.
You will for now need to adjust this link manually.
Guide:
https://wpml.org/faq/how-to-translate-links/
February 6, 2025 at 6:54 pm #16676912
vitaliiO
The Color Box Link is created using Advanced Custom Fields (ACF).
it's acf flexible content block (see screenshot).
it's set to "translate" (see screenshot).
February 6, 2025 at 7:09 pm #16676955
The Flexible Content field should be set to "Copy". Is this the case?
Source:
https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/recommended-custom-fields-translation-preferences-for-acf-and-wpml/
February 6, 2025 at 8:03 pm #16677054
vitaliiO
Let's try creating a "copy":
1. In the ACF settings, I set the **link** field to "copy."
2. I create a new page.
3. I add ACF flexible blocks to the page, where the **"link copy"** field is included.
4. I save the page.
5. I add the French translation by opening the page in the **Advanced Editor**.
6. The link does not appear in the list, meaning it is interpreted as internal.
7. translate automatically
8. Go to translated page. However, the link still points to the main language instead of the French version, even though a French version of the page exists:
**hidden link
February 6, 2025 at 8:23 pm #16677213
The Flexible Content field needs to be set to "Copy".
Can you please confirm?
For the link to show up inside the translation editor, you need to set the link field to "Translate".
All other fields should follow this guide, buy using the suggested field settings for the column "Same fields across languages":
February 6, 2025 at 8:32 pm #16677257
vitaliiO
yes, flexible content field is copy
February 6, 2025 at 8:44 pm #16677286
After making changes to the field settings you need to make a minor edit to the original page/post's link field and save the page/post again to generate a new translation job.
If you still do not see the link on the Advanced Translation Editor, please try using the search field on top and type "http".
If this does not work out, please let me know.
February 6, 2025 at 8:51 pm #16677290
vitaliiO
Now i see link in translation advanced editor.
But it doesn't translate link to french verison, it still points to main language page.
Flexible content is set as "copy", link field is "translate"
February 6, 2025 at 8:57 pm #16677315
You need to translate the link yourself in this case. The automatic translation can not create such translations.
February 6, 2025 at 9:00 pm #16677316
vitaliiO
Did I understand correctly that automatic translation cannot translate links to pages/posts, even if they have the corresponding language version?
February 6, 2025 at 9:38 pm #16677411
Correct, the translation engine (Google, Microsoft, Deep L) does not know anything about your website and will not know how to handle the URL.
This is why this field by default is set to "Copy", and will not appear on the WPML Translation Editor. In this case, it should automatically use the translated URL if you are handling an internal link and the page that you are linking to is translated and published.
February 6, 2025 at 9:50 pm #16677419
vitaliiO
I don’t quite understand. You said, **"it should automatically use the translated URL if you are handling an internal link and the page that you are linking to is translated and published."**
However, in my case, it does not automatically use the translated URL. Even if I set the link field to **"Copy"**, it still points to the main language instead of the translated version.
Even though the link points to an internal page that is translated and published, link still points to the main language. Why does this happen?
February 6, 2025 at 10:05 pm #16677430
We do have a known issue in regards to ACF Blocks with Links but there should not be an issue with normal link fields.
This might be because the link was already translated and a translation is saved in the translation memory of the translation editor.
Could you please give this a test on a new page or post using a link that has not been translated earlier?
1) Set the link field to "Copy".
2) Create a post and translate it.
3) Create a second post, add a link to the first post, and translate the post.
Does the issue persist?
February 6, 2025 at 10:17 pm #16677437
vitaliiO
I've created 2 new pages: test-page-1 and test-page-2. Did all the steps and the link still points to main language.
