Problem: User noticed big differences in loading speed of the same page with the base language and secondary languages. The secondary language pages take around the double of loading time.
Solution: Please deactivate the browser redirect function.
Additionally, WPML 4.3 version solved the performance issues that some sites experienced. Updating to the latest version of WPML and its add-ons should resolve the problem.
If you are running into performance problems, first follow our FAQ entry about preventing performance issues with WPML. This FAQ includes a number of simple steps to follow.
In case you want to profile your site's performance and get to the bottom of performance problems, follow the guide for debugging performance problems.
Last updated by Carlos Rojas 1 year ago.
July 3, 2019 at 10:24 am
marcoT-30
Hi, I noticed big differences in loading speed of the same page with the base language and secondary languages. The secondary language pages take around the double of loading time. Try in GTmetrix or other tool.
Base language (English)
Italian
Spain
Marco Todone
July 3, 2019 at 11:54 am #4135605
Carlos Rojas
1.- I wasn't able to log in the site using the credentials provided. I have set your next answer private so you can provide new credentials in a secure way.
2.- Could you tell me if you are using the browser redirect option?
2.- Please increase the PHP Memory Limit. Minimum requirements are 128Mb: https://wpml.org/home/minimum-requirements/
/** Memory Limit */
Kind regards,
Carlos
July 3, 2019 at 12:31 pm #4136293
marcoT-30
Hi Carlos, try now with this credentials:
user: ****
pass: ****
I have increased the memory but nothing has changed. Yes, I use the browser redirect language.
Marco
July 3, 2019 at 1:00 pm #4136599
Carlos Rojas
Please deactivate the browser redirect function and let me know if the issue persists.
Note: I applied some troubleshooting steps that should improve the performance of the site. Please visit this link where you will find some recommendations: https://wpml.org/faq/prevent-performance-issues-with-wpml/
Carlos
July 3, 2019 at 2:37 pm #4137493
marcoT-30
Thanks, now the things seems fine!
July 3, 2019 at 2:53 pm #4137675
Carlos Rojas
I'm glad to hear that the issue is solved 🙂
Please don't hesitate to contact us if you need our help in the future with WPML. We will be more than happy to help.
Carlos
